Ive owned this Syncrowave 200 for nearly 2 years. I was welding one of my stainless sculptures yesterday when it shut off. I immediately assumed the breaker flipped. Checked it and it was fine. Even plugged another piece of equipment into the 220 outlet to be sure and its working fine. I inspected all the plugs and cords. Next I took off the outer cover to see if anything looked like it got hot. Everything appears like it should be. Before I take it to be served, I wanted to see if anyone here, my have a suggestion. Thank you for any feedback in advance. Regards, Steve Nielsen
Syncrowave 200 shut off & not turning on.
So you turn it on and no display, nothing, or do you have a display.... if you lost a breaker, items will run on 120 being 230. So I have no idea what you plugged into the receptacle. Maybe turn the breaker all the way off, then back on.
If thats ok, maybe the on/off start on the welder switch has failed. Bad news from then on though.
Originally posted by cruizer View PostSo you turn it on and no display, nothing, or do you have a display.... if you lost a breaker, items will run on 120 being 230. So I have no idea what you plugged into the receptacle. Maybe turn the breaker all the way off, then back on. If thats ok, maybe the on/off start on the welder switch has failed. Bad news from then on though.
Originally posted by cruizer View PostYes, you are DEFINITELY missing a phase, your dryer uses 120 to power the motor, and a separate branch of 120 to power the heater for the dryer
