spectrum 625 X-TREME tripping breaker on 120volts
  • cope
    Are you connecting direct to the receptacle or using an extension cord?
  • cruizer
    Apparently some models of the 625 run on 120, and some models don't. All depends on the serial#. Personally If the machine is autoline, then I'd trust it to work properly. So if you have a newer machine, lower the nozzle sizes. Maybe having a fault there.
  • snowbird
    from product page
    Spectrum® 625 X-TREME™ with XT40 Torch
    Big cutting power in a small package - the industry's most portable and powerful 40-amp plasma cutter offers 5/8 in. mild steel cutting. The unit offers easy connection to 120V or 240V input with Auto-Line technology and MVP Adapters.
    confusing no?
  • griff01
    Originally posted by elvis View Post
    The spec sheet says it automatically reduces output to 27 amps for 120vac operation. The thread title states it is an xtreme model.
    Out of curiosity, I looked at the Spectrum 625 Xtreme spec sheet on this Miller website, and here is what shows for INPUT POWER
    :4-1. Specifications
    Power Supply
    Input
    Rated AC phase (PH) and line frequency (Hz) 1 PH 60 Hz — —
    Rated Input Voltage (U1) and rated Input
    Current (I1) and I1 eff at rated output. I1 eff used
    to determine power cord rating
    Volts AC RMS − (U1) Amps RMS − (I1) I1 eff
    208 1 PH
    230 1 PH
    No 120v as Cruizer has already stated.
    Griff
    P.S.
    There was also a warning about incorrect input voltage damaging the machine. Soooo.
  • elvis
    Originally posted by cruizer:323654
    I'd guess it would trip as there is NOT ANY 120 capability on a 625
  • cruizer
  • ericher69
    Make sure it's a dedicated 20amp circuit.
    Unplug anything else on that circuit.
    If it is try turning it down below max level on 120V
    Just a longshot; have you cut on this particular circuit previously?
    It could be wired as an arc fault interrupter circuit which will not run a plasma cutter
  • spectrum 625 X-TREME tripping breaker on 120volts
    as soon as i start cutting it trips the breaker? I've checked my settings and I'm running on a 20AMP receptacle and breaker? I may have skipped something in the manual...... any suggestions welcome thanks' dallas desantis
