spectrum 625 X-TREME tripping breaker on 120volts
  • spectrum 625 X-TREME tripping breaker on 120volts
    as soon as i start cutting it trips the breaker? I've checked my settings and I'm running on a 20AMP receptacle and breaker? I may have skipped something in the manual...... any suggestions welcome thanks' dallas desantis
    Make sure it's a dedicated 20amp circuit.
    Unplug anything else on that circuit.
    If it is try turning it down below max level on 120V
    Just a longshot; have you cut on this particular circuit previously?
    It could be wired as an arc fault interrupter circuit which will not run a plasma cutter
      I'd guess it would trip as there is NOT ANY 120 capability on a 625
        The spec sheet says it automatically reduces output to 27 amps for 120vac operation. The thread title states it is an xtreme model.
        MillerMatic 251
        Maxstar 150 STH
        Cutmaster 42
        Victor Journeyman OA
          Out of curiosity, I looked at the Spectrum 625 Xtreme spec sheet on this Miller website, and here is what shows for INPUT POWER
          :4-1. Specifications
          Power Supply
          Input
          Rated AC phase (PH) and line frequency (Hz) 1 PH 60 Hz — —
          Rated Input Voltage (U1) and rated Input
          Current (I1) and I1 eff at rated output. I1 eff used
          to determine power cord rating
          Volts AC RMS − (U1) Amps RMS − (I1) I1 eff
          208 1 PH
          230 1 PH
          No 120v as Cruizer has already stated.
          Griff
          P.S.
          There was also a warning about incorrect input voltage damaging the machine. Soooo.
            from product page
            Spectrum® 625 X-TREME™ with XT40 Torch
            Big cutting power in a small package - the industry's most portable and powerful 40-amp plasma cutter offers 5/8 in. mild steel cutting. The unit offers easy connection to 120V or 240V input with Auto-Line technology and MVP Adapters.
            confusing no?
              Apparently some models of the 625 run on 120, and some models don't. All depends on the serial#. Personally If the machine is autoline, then I'd trust it to work properly. So if you have a newer machine, lower the nozzle sizes. Maybe having a fault there.
                Are you connecting direct to the receptacle or using an extension cord?
