I'm building myself a flatbed to work off. While on site. I own all k size tanks at the moment. And haul my enclosed trailer everywhere. Trying to park the trailer . What size tanks do you guys with trucks carry . I'll be carrying argon and 75/25. Plus my torch setup. What's recommended .
what size welding tanks on service truck?
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#Tags: None
Also some pictures would help. I've done a lot of searching on the web for setups and designs..
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
And. What's the pipe frame rig welders have behind their welders does it have a purpose or is it just to keep the welder from getting banged up..
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
More information needed. What kind of work are you doing??? What kind of truck (weight capacity) do you have? How strong is your back, or do you have a forklift or loader tractor that you can use to remove and install bottles with?
About the frame on pipewelder trucks, mostly just to support an arm or boom to hang out over the pipe, holds the cables and cords and hoses so you don't drive over them. I do mostly equipment repair, and installation in industrial facilities, don't have a need for this. If I am wrong, anybody in the business, feel free to correct me.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
large oxygen. medium actylene
Originally posted by eecervantes83 View PostAnd. What's the pipe frame rig welders have behind their welders does it have a purpose or is it just to keep the welder from getting banged up.
KevinLincoln ranger 305g x2
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
F550 imt service truck
I own. A 97 dodge ram 3500. I work on tractor trailers on the side of the road. Most my work comes from truckers broken down..
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
My local norco has a loading dock I just back up to. No heavy lifting I just roll them off.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
It really depends on the work you do, How much you use your gas at a given time, How close your work area is to your gas supplier, Are you going to be using big rose buds Etc., Do you have room on your truck and weight capacity to carry big tanks.
If you only go through a couple tanks a year then go small, If you go through the gas in a week then go big.
Originally posted by Portable Welder View PostIt really depends on the work you do, How much you use your gas at a given time, How close your work area is to your gas supplier, Are you going to be using big rose buds Etc., Do you have room on your truck and weight capacity to carry big tanks.
I would look into buying some small shielding gas tanks, 20 or 40 cu. ft. capacity. You probably won't be able to exchange them, like you can with normal tanks, have to send each one in to be refilled, and wait a week or so to get it back. Buy two of each, one is out and one is on your truck. Big advantage, cuts the weight you are carrying way down. Leaves more capacity for carrying tools, parts, and metal, which may be more important.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
Originally posted by eecervantes83:323553And. What's the pipe frame rig welders have behind their welders does it have a purpose or is it just to keep the welder from getting banged up.Last edited by fencemaker; 09-04-2014, 10:52 PM.
Originally posted by JSFAB View PostWhat Portable says here is valid. Based on my own experience, you should have a #4 acetylene (standard size), either one or two 125 or so Cubic foot Oxygens. Bigger is better, but you don't have a big enough truck. Having two smaller tanks allows you to go out with an almost empty, and switch over if necessary to a full.
I would look into buying some small shielding gas tanks, 20 or 40 cu. ft. capacity. You probably won't be able to exchange them, like you can with normal tanks, have to send each one in to be refilled, and wait a week or so to get it back. Buy two of each, one is out and one is on your truck. Big advantage, cuts the weight you are carrying way down. Leaves more capacity for carrying tools, parts, and metal, which may be more important.MillerMatic 211 Auto-set w/MVP
Just For Home Projects.
Depends a lot on your location, and your LWS. Just checked with mine today, they exchange ownership cylinders down to 80 cf. They do on occasion send in smaller oxygen cylinders, for refilling and sending back to the customer. Guy wasn't sure about small shielding gas cylinders. I will check with Airgas and see if they can do it, either filling or exchanging.
Tractor Supply and others are selling them, somebody's got to be filling them.Last edited by JSFAB; 09-05-2014, 03:24 PM.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
Here is chart with dimensions and weights which may help.Attached FilesMiller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, large first aid kit, etc.
Originally posted by JSFAB View PostDepends a lot on your location, and your LWS. Just checked with mine today, they exchange ownership cylinders down to 80 cf. They do on occasion send in smaller oxygen cylinders, for refilling and sending back to the customer. Guy wasn't sure about small shielding gas cylinders. I will check with Airgas and see if they can do it, either filling or exchanging.
True I have a co2 bottle for a kegerator that needs to be "filled" and not exchanged, but we were talking shielding I think...?MillerMatic 211 Auto-set w/MVP
We have a couple 20# aluminum co2 bottles that have an argon valve and filled with c25 for portable stuff. Pretty handy. Just swap them at airgas just like I do with my beer co2(5#-20# tanks). I believe the 20# tanks are rated for 60ft3 of argon/co2 mix. They are nice and light and very portable. They don't last that long though.MillerMatic 251
Maxstar 150 STH
Cutmaster 42
Victor Journeyman OA
