HF-251-D1 power sources
  • HF-251-D1 power sources
    What welding power sources are compatible with an HF-251-D1 high frequency spark starter?
    Any CC, DC or AC power source,
      Thanks, but more to the point...
      Let's say I had a Millermatic 180 that provides an output of 135 amps at 22.5 volts DC with a 30% duty cycle. Would that work?
        no....
        no as that is a cv....ie constant voltage. As you need cc..ie constant current to tig weld.
        Lincoln ranger 305g x2
        Ln25
        Miller spectrum 625
        Miller 30a spoolgun
        Wc115a
        Lincoln 210mp
        F550 imt service truck
          Going to guess and say that you have zero clue on what a HF box is for, maybe do just a little research.
            Info...
            I love dry humor.....
            here is a link to the manual... just plug in your serial number..
            http://www.millerwelds.com/service/l...&submit=Search
            should give you a better idea...
            Seems like you might find a bunch of useful info in the Resources section...
            http://www.millerwelds.com/resources...g-your-skills/
            H80N
            Senior Member
              Very astute observation
              You are the quite clever observer! I got this equipment from a friend who does no welding at all and he thought it was a TIG welder. It took only a brief read of the manual to determine what it is for (starting the arc using high freq) but alas the manual only references connecting to "the welding power source" which left me disappointed in the completeness of the manual. I looked through the Welding Discussions here without much additional enlightenment. Thus asking via this forum seemed to be a good way of doing the needed research.
              Thanks for your comment as I am sure it must be helpful in some way.
              The constant current versus constant voltage comment from another member was very helpful though.
                Worth your while to do a lot of reading here...
                it will give you the basics...
                  I told you what power sources the unit was ment for, then you came out with how to use it with your CV mig.... What am I supposed to think?
