Syncrowave 210 will not boot up
  • Syncrowave 210 will not boot up
    I just bought a Miller Syncrowave 210 welder two weeks ago
    today I welded for some time
    took a break for lunch
    turned it back on
    display board displays Syncrowave 210
    no menu options come up
    any suggestions
    Thanks
    Bob
    Turn your breaker off then back to on . Your missing a phase
      It is a single phase 110/220 machine
        Are you running it 220 ? Just flip the breaker off and back on like cruzier said.
          I was using the machine on 110 Volts
            OH, yeah its one of those odd units. It's likely stuck on 220, best bring it in, as its having voltage switch issues. The unit senses input voltage, and isn't sensing to drop to 120
              I’m having the same problem with my syncrowave 210. Did you ever find a solution to this problem?
                How much voltage do you measure from heatsink HS6 in reference to heatsink HS2 when the unit is turned on?
                It should measure about 440 VDC when the boost circuit is operating properly in the PC1 board.
