I have the identical problem another posted described with this machine SN KH422829. Have power at the convenience plugs but no weld power. I will begin trouble shooting next week as the tech manual and experts on here have suggested. The previous owner told me he did "jump start" the welder a few times. From reading, I think that is the death move for these machines. The main reason for this new thread is I'm wondering what everybody does with their bad PC2 and other boards? I was an electronic technician in my working life and I might be able to fix a board by troubleshooting down to a component. I'll post my progress when I get started. Thanks in advance.
Another busted Trailblazer 251 with only 290 hours! Anybody have bad PC2 boards?
Went backwards
Well, today, I took the covers off and decided to check some diode readings, look at the brushes, etc. While taking a wire off CR 2, the lead came out of the diode. So, off to the electronics store. Luckily they had one. Replaced that and started it up. Now, instead of 120 VAC at the convenience plug, I have 24! I rechecked the replaced diode and the wires, checked the brushes, looked all around but could find nothing different. How do you perform this step: "Disconnect leads 23 and 24 from brushes and check continuity across slip rings" If I read this correctly, you'd now be reading from one brush through the rings to the other brush. What kind of reading in ohms should I get? Do you stick the commutator stone through the brush holder when stoning the rings? Where do you get one to fit the brush holder? Where does one buy a stone for this job? Thanks for any help in advance. May have a good Onan motor for sale here shortly.Last edited by denwhit; 08-27-2014, 04:31 PM.Millermatic 200
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
On slip rings I use and recommend just 320grit or finer sandpaper applying just enough pressure to clean them.
Specific component failures on Trailblazer Power and Control boards vary but optocouplers, transistor gate resistors, zener diodes and IC chips are among the list. Anyone repairing these boards needs to keep in mind a component failure on one can cause one or more component failures on the other in applications that involve both Main Control and Power boards.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
Originally posted by duaneb55 View PostOn slip rings I use and recommend just 320grit or finer sandpaper applying just enough pressure to clean them. Specific component failures on Trailblazer Power and Control boards vary but optocouplers, transistor gate resistors, zener diodes and IC chips are among the list. Anyone repairing these boards needs to keep in mind a component failure on one can cause one or more component failures on the other in applications that involve both Main Control and Power boards.Millermatic 200
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
I appreciate the compliment but I'm no expert by any stretch of the imagination. I'm more the blind squirrel that finds a nut once in awhile.
If you're now only getting 24VAC at the auxiliary outlets my guess is you're only getting 12VDC flashing voltage (battery +) across the brushes.
If that's the case, I would check for a blown exciter output fuse F1 and/or failed exciter bridge rectifier SR3 for starters.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
Originally posted by duaneb55 View PostI appreciate the compliment but I'm no expert by any stretch of the imagination. I'm more the blind squirrel that finds a nut once in awhile. If you're now only getting 24VAC at the auxiliary outlets my guess is you're only getting 12VDC flashing voltage (battery +) across the brushes. If that's the case, I would check for a blown exciter output fuse F1 and/or failed exciter bridge rectifier SR3 for starters.Millermatic 200
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
Yes, LED #2 and #3 should be lit when the board is energized.
Did you check DC voltage between the center and rear slip rings?MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
And your resistance reading between the center and front rings is a little low and should be 31ohms but the exciter rotor would be good at 12-12.5ohms.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
Originally posted by duaneb55 View PostAnd your resistance reading between the center and front rings is a little low and should be 31ohms but the exciter rotor would be good at 12-12.5ohms.Millermatic 200
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
I wouldn't throw in the towel just yet.
Enjoy the vacation!
BTW, if you can't find me here on the Miller sight, I spend most of my time over on WeldingWeb http://weldingweb.com/forumdisplay.p...&s=&daysprune=MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
Originally posted by walker View PostFWIW, mine turned out to have a broken wire in one of the wires going down to the slip rings. The terminal in one of the molex connector cracked. Since the other wires were fine, that one stayed in there, but didnt excite the generator.Millermatic 200
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
