Millermatic 35 wire overheating just prior to feed roller assembly
  • Millermatic 35 wire overheating just prior to feed roller assembly
    More precisely just to left of figure 94 " conduit stub liner "
    Possibly unrelated slight sparking when ground clamp is attached to self grounded structure.
    When welder is turned off without ground clamp connected to structure residual potential exists. when clamp is discharged to grounded structure rapidly discharges with little apparent current.
    Have experience in electrical troubleshooting but no experience or even familiarity with welders.
    Any suggestions would be appreciated and I would not be unhappy if I am missing the obvious.
    Thanks
    Grounded
    Your gun is damaged, ,ie, one of the ends that holds the condiut has pulled apart. The minor spark is merely the caps draining, nothing unusual....
      Recomedation and source for replacement gun ?
      Thank you very much for the advice
      Could you recommend a replacement all components on gun and fitting on welder are labeled Tweco
      Thanks
      grounded
        Just take it apart and fix it....For that unit I would use a good nickel tywire to put the conduit back on, unless the inner gas tube has also pulled out, but its pretty self explanatory once you get it apart
          If the wire is burning off to the left of the conduit stub liner, pull your spool of wire and snip off the end of wire that's making contact with the inside wall of the welder cabinet.
          Syncrowave 180 SD
          *HF-251D-1
          *WC-1S & Spoolmatic 1
          PakMaster 100XL
          Marquette "Star Jet" 21-110
