Torch hookup issue Dialarc HF
  • Torch hookup issue Dialarc HF
    Bought a older Dialarc hf the other day has a water cooled tig torch
    that had a large fitting on gas hose. But machine has the small fittings
    like the size of the water like 3/8 or so. What has been changed?
    is there something missing? Will a different air tourch work? Thanks
    Cause your missing the tig block
      Tig block?
      What does it look like? Does it fit in one of the other fittings?
      thanks.
        Tig block goes to your elecrode output stud, , fits the air cooled tig torch, and with a smaller hose going to your gas adaptor on your machine. You'll need a short chunk of gas hose with fittings as well
          Tig block
          Oh ok, where can I find one
            Local welder supply
              Tig block
              Hate to be so dense but on the welder it has two large studs one on left says work! The other says electrode! Is work the ground? And electrode the tig where the tig block goes? And does the gas out connection go to the small side of the tig block? If so there must be a small jumper gas hose right? Thanks
                Well you have a switch to reverse the polarity, however work clamp goes to the left, tig torch to the right, I mentioned you'll need a "short chunk of gas hose" for the machine and tig block.
                  Tig block
                  Thanks.
