Aloha. First and foremost, if there are rules that one has to post an introduction before seeking help...sorry.
Ok now to the topic.
I have read up on prior posts. .still I am lost.
I bought a brand new
millermatic 211 autoset
Running .030 solid wire
110 v.
Argon co2 mix
Trying to fix before I hand it to warranty department as I can't wait a week with no welder..too busy :-/
Where the wire passes through the drive wheels...and enters the gun cable....the wire is shorting.
The miller approved repair facility said..." never heard of that before".
The local weld supply shop reckons they have heard about it a few times.
Its only started happening since I've been working at this one older house, most likely with bad electricity (old wiring)
Could a lack of amps do this?
So far I have isolated the project from the welder. The project is on a plastic table with rubber feet.
I have removed the gun and cable from welder...cleaned all brass.
I have taken off machine covers, blown out dust and inspected for possible shorts.
I have cut the inner liner back closer to the brass just incase there was a kink I couldn't see. .
My issue is nothing to do with the tension. I'm sure of that.
I have the negative connected to the ground clamp.
Ground clamp and wire are both new and in excellent condition.
My gun wire is ten foot, wrapped in leather for protection.
Any ideas what's wrong? Please help.
I have been welding for years, owned a few machines...this is my first miller....so maybe something obvious is staring me in the face.
110 v.
Argon co2 mix
