Hey guys I'm in a pickle here! Im welding chromoly for the first time and that well actually other than when i weld it it gives off a awkward smell and I just mention this to see if this related to my problem. Now first thing is the fact that im getting horrible contamination when welding aluminum. So far what I have done...Checked for Leaks (argon) , made sure tank is argon, tried 3 different tugstens(2 2% Lanth-1 Pure), tried diff. filler rod (new bag of 4043. changed collet and body(using screened collet body), used 6 7 8 9 cups, turned cleaning action up to the point of tungsten melting, tried gas flow to point of arc blowing out and down to no gas, also tried 4 different pieces of stock all 6061 t65 mill stock fresh and clean. So this is weird i had my machine dialed in and changed nothing before all this trial and error. since this worked great the only thing I have changed is I exchanged my argon tank for a new one. now it has to be tank in my eyes it worked fine just before so am i wrong? What else could it be? does anything happen tanks that could cause peppering, contamination? thanks zach
HMMM Need help Contamination Aluminum
Originally posted by nissan20det View PostHey guys I'm in a pickle here! Im welding chromoly for the first time and that well actually other than when i weld it it gives off a awkward smell and I just mention this to see if this related to my problem. Now first thing is the fact that im getting horrible contamination when welding aluminum. So far what I have done...Checked for Leaks (argon) , made sure tank is argon, tried 3 different tugstens(2 2% Lanth-1 Pure), tried diff. filler rod (new bag of 4043. changed collet and body(using screened collet body), used 6 7 8 9 cups, turned cleaning action up to the point of tungsten melting, tried gas flow to point of arc blowing out and down to no gas, also tried 4 different pieces of stock all 6061 t65 mill stock fresh and clean. So this is weird i had my machine dialed in and changed nothing before all this trial and error. since this worked great the only thing I have changed is I exchanged my argon tank for a new one. now it has to be tank in my eyes it worked fine just before so am i wrong? What else could it be? does anything happen tanks that could cause peppering, contamination? thanks zach
Are you welding on AC not DC.sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
Pics.. Settings.. Machine...???
weld pics..??
what type of aluminum are you welding?? thickness?? (you said 6061 is it marked??)
How do you think this relates to chrome moly..??.. smell??
Have you looked here..?? look familiar..?? peppering..??
Welder brand..?? model??
settings..?? ac balance..?? frequency??
physically clean the aluminum with dedicated wire brush or abrasive just before welding??
acetone wipe??
tungsten stickout..?? size..??
argon flow cfh??.... backcap o-ring ok..??.
Go with your first gut reaction- the only thing you changed was a new jug of gas. take it back and try a new jug.
Bad jugs of argon do happen.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by H80N View PostWelder brand..?? model?? settings..?? ac balance..?? frequency?? physically clean the aluminum with dedicated wire brush or abrasive just before welding?? acetone wipe?? tungsten stickout..?? size..?? argon flow cfh??.... backcap o-ring ok..??
Originally posted by nissan20det View PostLuxor Ebay 200p and I love It Using pedal, pulse off, Ac balance I always use at about 40% electrode Pos and tried As high as i could go till tungten was melting off no difference, Fixed 60HZ, Stainless brush ONLY for Alum(even bought new one), yes tried acetone wipe, tungsten 3/16 2% Lanth. at 3/16-1/4 past cup, Yes Tungsten cover oring brand new (also did Bubble Leak down test no leaks), argon flow I tried to point of arc blow out and down to no gas(as I increased I just had turbulence no change in Bead quality) Im telling you this was a day to day change old bottle fine new one problems??
set your balance to 70% negative raise your amperage and move faster...
Tungsten prep?? ground to taper and blunted??
Broc may very well be right about a bad bottle of gas... it does happen... not often in my experience... but you may have drawn the lucky ticket... you might try trading it..
but usually it turns out to be operator related..Last edited by H80N; 06-18-2014, 04:29 PM..
Okay guys I figured it out!!!! If was the bottle for sure... Hit up high plains welding(Denver CO supply store) and said it getting bad bad contamination and a funny smell they said "well can you stop by today to swap her out". I was shocked lol they took that well... So I got there said I was the guy on the phone and I asked is this a common thing to happen, are you convinced it's the tank as well and the said that it's not common (didn't think so) but the said that diff. Your problem. I asked how they new and it's that funny smell I slightly mentioned. He said that's the signs of a bad bottle. Turns out I was the first person to use it since it's new test date certification so they think some of the purging chemicals for X-ray where most likely left behind.... Crazy.
Well lol I hope my experience helps other people out... If you changed nothing but your bottle and you do your dumb dumb check list and all things check out check for a funny smell ON mild steel, stainless steel, or chromoly and your aluminum is dirty as all **** ..... BOTTLE!!!!!!!
Thanks for all the help guys! Truly appreciate it!
pics.... Some stainless and aluminum with new bottle one pic has all my peppered welds with one bead on it with the new bottle
Glad you got it sorted out....
Thanks Again, Ya so I always used the 10N series collet body and I just picked up the medium screened gas lens and WOW!!!!! what a difference in coloration with stainless its unbelievable! If anyone is having troubles with that beautiful coloration of stainless and just cant quite get it. Change from 10N collet to screened gas lens you wont regret it I promise! Have you guys heard of using L310 filler with 4130 chromoly? I know ER70S-2 is the best for not preheating or annealing and ER80S-D2 if you do so, but 310 I heard some people says it works great. does anyone know what tinsel strength 310 has? or had experience with 310?
Originally posted by nissan20det View PostThanks Again, Ya so I always used the 10N series collet body and I just picked up the medium screened gas lens and WOW!!!!! what a difference in coloration with stainless its unbelievable! If anyone is having troubles with that beautiful coloration of stainless and just cant quite get it. Change from 10N collet to screened gas lens you wont regret it I promise! Have you guys heard of using L310 filler with 4130 chromoly? I know ER70S-2 is the best for not preheating or annealing and ER80S-D2 if you do so, but 310 I heard some people says it works great. does anyone know what tinsel strength 310 has? or had experience with 310?
using stainless as a filler for 4130 was a fad about 30 years ago in some racing circles...(I did some of that myself)
I will stick with the proven safe fillers ER70S-2 & ER80S-D2
Here is an AWS article that covers it
Originally posted by nissan20det View PostYup true that! ill stick with 70S-2 What grade stainless to you start using 316L rod on and Aluminum i was told 4043 is good up to 6061 T65? at what point do you move to 5356?
here is a selection chart
Global Welding Community Providing Resources & Education For The Industry. Our mission is to connect and serve our members in multiple countries with A-Z welding resources, educational videos, how-to series, job opportunities, industry connections and much more!
For Aluminum 4943 covers all of the places you would use 4043 and a bunch more
here is a thread you might want to read..
