Hey all
So I am doing some AC TIG, things are working great. 1/4" aluminum so I have it set to 200 amps and working the peddle.
Then.... dead I figure I overheated even though the fan was running and the air out wasn't very warm and I was just tacking these parts together, so about a minute per and set the next.
I didn't see any help or alarm codes. I turned of the machine, unplugged it and let it sit for about an hour while I did some other things.
Plug it back in, turn it on. Here's what I have. The remote won't trigger anything AC or DC. The lift arc works on both, the pulse and other specials settings work.
The remote peddle, remote on/off, and the remote thumb controls don't work.
Before I dig in to see what I can see inside the case, can someone give me a hint where to start looking? It has to be an internal contactor, I just don't know if it is mechanical or electronic.
Maybe a fuse? The owners manual isn't much help.
Hey Cruzier what do you think.
LJ060154C
Thanks in advance
Harold
LJ060154C
Thanks in advance
Harold
