Thicker stock, running beads, lap joints, and fillet welds are no problem. 16 gauge 6061 butt welds or outside corner joints run well for inches, then keyhole, and start to form a grey "skin", It becomes hard to get a shiny puddle to form. I struggle with it eventually getting the hole filled. I don't notice the inches of perfect, I notice the ugly mess I had to fix. I can't help thinking it is a gas issue, I've usually used 12-15 CFH with gas lens with #8 cup, and 3/32 thoriated or 2% lanthanated ground long point and blunted like a slightly used pencil. I find it difficult to use 4043 1/16" 3/32" is less prone to melt before it reaches the puddle. Bringing it in from the side seems to help a little, but doesn't cure the problem. I'm holding the torch 15 degrees off perpendicular to the bead, and square to sheet or splitting the difference for the corner joints. A copper backer doesn't seem to help.
How do I fix this?
How do I fix this?
