Invertec 200. won't power on. help!!!
  • Invertec 200. won't power on. help!!!
    Ok guys,
    I bought this machine from a reputable guy on eBay.
    This guy had 8 eight of them. took them out of service, they wired 480v.
    I got the machine, was full of dielectric power. normal I guess.
    I put the 6-50p on it.
    Switched the switch on the back to 230.
    Plugged it in, and nothing happens.
    I talked to the seller, I trust him.
    That's beside the point.
    Pics
    Let me know if you need more pics or info.
    Thanks,
    ~John
    Life is to short for cheap tools.
    That's a very old machine.
      In case you do not already have it...
      here is the operators manual..
      maybe there is something in there about setup switchology that will fix it...
      did notice that they don't want it to be powered by a generator..
      "The V200-T should not be powered from the auxiliarypower supply of an engine welder. Special protection
      circuits may operate causing loss of output".
      so maybe it is a bit finicky about supply power??
      is that one of the Italian Lincolns..??
      I see it is about 1995 vintage...
        Thanks H80N,
        The switch on the back is the on/off switch.
        So,
        The only thing left is that the plug is wired correctly?????
        Is it???
        Looks right to me, I've wired up about ten machines the same way.
        Still running.
        Green is the top(ground) and black and white can go to either of the bottom ones,
        Am I right???
        ~John
        Or it might be that 0.5 amp slow blow fuse.
        Anyone???
          I would read the WHOLE manual and go through everything... including any fuses...
          a lot of times it is the simple obvious stuff that bites us..
          6-50 wiring illustration... courtesy of BROC....
            I'd check with an ohmmeter while it is unplugged. Black and red would be the standard Hot conductors. Black and white for 120 Volt configuration. This is not true with my new Dynasty with "Auto Line". These machines use red only for 3 phase. Sorry I don't understand either.
            Dynasty 280DX
            Bobcat 250
            MM252
            Spool gun
            Twentieth Century 295
            Twentieth Century 295 AC
            Marquette spot welder
            Smith torches
              Red would be one of the hot legs on most 240 volt equipment. White is used only when 120 volt is needed. This does not hold true on my new Dynasty. Red is used only on three phase.
              Dynasty 280DX
              Bobcat 250
              MM252
              Spool gun
              Smith torches
                This machine had the plug on it you see in the eBay link.
                It had three wires.
                No red one.
                I'm sure I wired the right plug to the right terminal.
                I don'y understand it.
                I'll get you some better pics of the wiring in the morning.
                ~John
                  Ok,
                  I found the 0.5 amp fuse.
                  Now since its not clear, how do I tell if its any good???
                    Originally posted by AKweldshop View Post
                    Ok,
                    Do you have a Multimeter?? and know how to use it to check the fuse continuity (out of circuit, removed from board)
                    if not.. find a friend that is competent in it's use..
                    MAKE SURE THE WELDER IS UNPLUGGED BEFORE YOU TOUCH ANYTHING!!!
                    From the Operators manual... page 22
                    The machine is dead - no output -
                    no fan.
                    1. The input power switch must bein the ON position
                    2. Make sure the input voltage iscorrect for the machine.
                    3. Check continuity of the 0.5-ampslow blow fuse located on the
                    P.C. Board.
                      not a 3 phase machine is it?
                      Ok guys,
                      Pics
                      [ATTACH]33969[/ATTACH]
                      [ATTACH]33970[/ATTACH]
                      [ATTACH]33971[/ATTACH]
                      [ATTACH]33972[/ATTACH]
                      [ATTACH]33973[/ATTACH]
                      Thanks,
                      ~John
                        I can't read the nameplate. Will it configure to 240 Volt single phase? Might it be possible to download a manual? I wonder if the way it is linked for 480 it won't recognize 240 as useable power supply. Most machines have connection diagrams on or in the supply enclosure.
                        Dynasty 280DX
                        Bobcat 250
                        MM252
                        Spool gun
                        Smith torches
                          Willie
                          I gave him a link to the manual in post #3.....
                            Willie
                            I wasn't able to open the link. The red lead has me wondering.
                            Dynasty 280DX
                            Bobcat 250
                            MM252
                            Spool gun
                            Smith torches
                              Willie
                              You may have a point there......
                              Easy enough to check which color wires are connected on the WELDER side..
                              that machine is single phase only so it may not follow the same convention used on the Miller Dynasty wiring...
                              if it is not connected... it will not power up....
                              Try this link to the Manual
