Just bought this spoolmate and dont know how to hook it up to my millermatic 300. The gun has two sets of leads that go to the welder; one has 3 wires, the other 4. They are labeled 13,14,23 and 15,16,21,22 respectively. Any help would be greatly appreciated, Thanks, JR
Millermatic 300 with Spoolmate 2 200 amp gun
Based on the wire numbers you listed I believe you meant Spoolmatic 2 as opposed to Spoolmate 200. The older Spoolmatic 2 requires its WC-2 weld control in order to be connected to and used with a host of machines.
However, the Spoolmate 200 can be used with the MM300 and whether the 300 is the meter version or not determines if the SM200 is a direct connect (nothing else required) or if the WC-24 weld controller is needed (non-meter unit).
The higher capacity Spoolmatic 15A and 30A units can be used with the MM300 as well.
http://www.millerwelds.com/products/...gun-chart.htmlMM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
