Forney Inverter help needed
I bought one for sport to see if a 100$ welder worked,,, yes and no. It is a 3/32 6011 unit period. Its not efficient enough to run a 3/32 lo hi. Not worth messing with a fix. For another 100 or so someone,,, green maybe, makes one a lot better.
Originally posted by Texas113 View PostI appreciate getting back to me about that. Are there any wiring diagrams out there for the HF models?
https://www.forneyind.com/customer_service/
Hopefully they could help you...
I had a TA Dragster 85 I got for $50. then flipped it and got the TA 161STL. Gave that to my son, the welder.
Originally posted by USMCPOP View PostI never had a Forney AT-100. My son had a little Harbor Freight inverter but sold it. I believe Forney had trouble with those welders. A lot of them showed up on eBay really cheap when they were discontinued.
Thought you had one of them..
You may have cooked the thermal overload switch...
I believe that USMCPOP has one of those little Chinese Forneys...
maybe he could shed some light on your problem
Long story short. My dad let me try out his little inverter welder and I pushed it harder than should. It is a Forney AT-100 inverter stick/ TIG unit. I was trying it out with 3/32 7018 rod maxed out. About 3" of weld total. I then waited 5 minutes and ran 3" of 6013 when it turned off. Is it true Forney slapped their name on the Harbor Freight equivalent ? I can't get it to run again. It also has a constant on fan that will not run. Any info would be great. I just don't want to tell him his poor little welder was burnt up by me. Oddly enough the thing had great penetration on prepped and beveled 1/4" box steelTags: None
