Plasma 375 120 V output, Dynasty DX
  • H80N
    FLAT-OUT
    like your kitchen layout very much... you live in a great area for the fabricator/found object artist to work with.. you might be able to save a bunch of money (and placate your wife).... the surplus that comes out of SANDIA/LOS ALAMOS... plus folks like Intel out of Rio Rancho.. provides a vast pallete of raw material... Intel cleanroom stuff is electropolished stainless and looks like very high quality restaurant kitchen stuff (and they change it all of the time to keep up with technology) stuff out of the labs is so varied that it boggles the mind... might take a trip down to the state fair flea market in Albuquerque on a weekend and just look around.. also surplus city in ABQ on central gets stuff.(look out in the yard).. plus the scrappers... pennies on the dollar for your needs is my guess... (would have sent this to you offline but your email was not available)... you might have guessed.. i was a secret squirrel scientific type at Sandia for many years..
    hope to continue this offline...
    great project and i wish you the best...
    Heiti
  • Flat-out
    guys,
    Thanks for the TP links and DEA - yes I am getting the contractor kit so that's great.
    Flat-out
  • DEA
    flat out
    If you bought the contractor kit with your dx200.You'll get the collets,cups,holders ect.and thoriated tungsten from.040 to 1/8
  • H80N
    Probably closer to what you are looking for is the "official" type of water removal toilet paper filter..
    here is a link
    tnx
    Heiti
    http://www.tptools.com/product.asp?b...MJM6VAVCSMF3N4
  • H80N
    Guys
    on the toilet paper filters... they used to be quite an item at county fairs and in the back of magazines during the 50's and early 60's.. for cars that did not come with an oe filter..(intended for motor oil but work wonderfully well at removing water from compressed air). made by a company called "FRANTZ" i believe... see them quite often at garage sales and flea markets...for a couple of bucks.. keep your eyes open.. ones that i have seen are usually chromed... will try to see if they are still made by someone.. and let you know
    thanks
    Heiti
    Additional info: yep they are still being made.. but would probably still opt for one at a garage sale... here is a link to links with more than you ever wanted to know about them
    http://search.yahoo.com/search?p=fra...t&cop=mss&tab=
  • Flat-out
    HAWK and DEA,
    It looks like I'll try the lanthanated (as in lanthanum, check spelling) and ceriated and see how it goes. The 1/16th and 3/32 should suit me for a while. I'll have to buy collets (right?) for the thinner stuff so I'll probably wait on that. Perhaps I'll try to buy one stick of thoriated for comparison.
    I have the same questions about chem-sharp.
    DEA - the 1.5% La is used since it's resisitance most closely matches 2% thoriated, and thus those that have used that for a while would not have to tweak thier settings when doing the "non-radioactive switch" to lanth. How the 2% compares in absolute performance I'm not sure.
    My Dynasty has not shipped yet, but I'm trying to be patient...
    I'll have plenty of pictures later, you guys won't believe what I'm doing w/ my new house and "Monster Carport" (hint - suspended workbench w/ hoist)
    Flat-out
  • DEA
    Hawk or anyone
    What kind of a difference will the 1.5% compared to the 2% make in the tungsten of
    either lanth or ceri.?
    Also do you have any pulser settings for the Dynasty 200 dx I could start out with?
    And how well do the chem. sharpners work?Do you put a point on the tungsten and soak it in the chemical to resharpen it?
    DEA
  • HAWK
    Flat-out,
    In response to:
    I purchased some 1/16 and 3/32 WCe and some 3/32 W1.5La. I have now come across some old posts on Hobart (there certainly are a lot more users there) that state that the ceriated stuff can’t take heat. It sounds like the 1.5 lanthanated can be used for DC and AC w/ the Dynasty. How many thicknesses do you use practically (ever hear of anyone using the 0.020 for hand use?) and which alloys do you use?
    Tungsten alloys are available down to 1.0mm and 0.40inches. There may be smaller sizes that I am not familiar with. Here's a color code chart to identify types.
    1% Thoriated (Yellow Tip)
    2% THORIATED TUNGSTEN ELECTRODES (Red Tip)
    PURE (Green Tip)
    0.5 % ZIRCONIATED (Brown Tip)
    1% ZIRCONIATED (White Tip)
    1% LANTHINEATED (Black Tip)
    1.5% LANTHINEATED (Gold Tip)
    2% LANTHINEATED (Blue Tip)
    2% CERIATED (Grey Tip)
    3/32" and1/8" will do 90% of my work.
    0.40, 1/16, 5/64" are my next choice for very fine work.
    Ceriated won't take the heat on DCSP. However, it does fine for aluminum. I am sure specific prodeures for GTAW certs are written with specified diameters, %alloys, amps/voltage range, etc.I don't know all the parameters and reasons. Give me a procedure your in question of and I'll have my CWI take a look if you want. I use 1.5% lanthineated, and 1/8" ceriated in most cases. I have accumulated many alloys: mostly in 3/32" and 1/8". 5/32" and 3/16" are out there for heavier work. You won't need anything over 1/8" for the Dynasty 200DX unless you are playing with 50%/50% helium/argon or a hotter gas(more helium and less argon-i.e. 90%/10%.
    I do like 2% thoriated for DCSP steel tig, but use "Chem-Sharp" or grind out of doors. I takes the heat well and likes the negative side of the wave-sine or square. Keep in mind I am speaking from my operating the Dynasty 200DX. The Syncrowaves and other machines perform different with these alloys due to their different arcs-non inverter type machines.
    I hope your Christmas was great and Happy New Year!
  • mowjunk
    Flat, I have used a .040" tungsten, but I think the 1/16" and 3/32" would do for just about anything I weld. I don't have an inverter machine so I'm not sure if the smaller tungsten would be an advantage or disadvantage on the inverters. I have about three of the .040", just in case I would ever find a need.
    If you build the barrier, don't forget to post a few pictures of it. We like pictures....
    mow
  • Flat-out
    Gracias MOW,
    I hadn't seen that one.
    I'm still wondering from those on the board whether folks actually use the really small diameters, or do most just use the 1/16 or 3/32 and turn it down for real thin stuff.
    Flat-out
    ps - went on a great hike today w/ the new dog - one of my first projects will be a "barrier" in the back of my Blazer to keep the mud and hair back there. They charge $70+ for those at Petsmart.
  • mowjunk
    Flat-out,
    I don't know if you've been here, but it may answer a few of your questions about different types of tungsten. It seems to be geared more toward the inverter type machines and not the Syncrowave type like I have...
    http://www.millerwelds.com/pdf/gtawbook.pdf
    You can see more pamphlets here:
    http://www.millerwelds.com/education...pamphlets.html
    Hope this helps you....
    And Merry Christmas to all!
    Mow
  • Flat-out
    Hawk,
    Still wondering about tungsten types and diameters for the Dynasty.
    See my previous post near the bottom.
    Happy holidays
    Flat-out
  • HAWK
    Flat-out,
    I usually run my 2050 around 47 amps for most materials from 1/4" up to 1" thickness. Even though it will push 55 amps output I don't because it really drags my Trailbazer down and actually reduces the effective cutting thickness. For 3/16" and less I tune it down around 30 amps. I like to run the output as high as possible while still getting a good quality cut.
    My neighbor's shop runs a 625 wide open for everything except 1/8" and under. Just experiment. Be sure to check your air pressure with the air flowing through the torch. Once you are getting a clean cut, then vary the amperage up and down 3-5 amps and see where your cleanest cut is achieved.
    Tips are not that expensive and last fairly well unless you are cutting lots of aluminum. I like to clean the aluminum "needles" out of my tip every few linear feet of cutting. This greatly improves performance and tip life. Don't over tighten your torch nozzle assembly-finger tight only-not even hand tight. Over tightening can close up the gap necessary for establishing the pilot arc and create headaches you don't need. Most manufacturers recommend changing the electrode and the head parts when replacing the tip. I don't do it. That's not to say I'm correct, but it costs several dollars and I have not seen any performance benefits. I usually change the head guts when they look crusty and or can' get a good cut.
    I do only have the water separater on my pontoon compressor in the field. I have a water separator and the Waterguard dessicant filter on my shop compressor. It seems to spit a lot more moisture. Well I had both until I recently broke my water separater.
    I use a plasma cutter when there is a lot to be done or the metal is over 1/4" or thicker. I guess it depends on my mood.
  • Flat-out
    HAWK,
    Thanks for the reply. Certainly no need to apologize.
    I will certainly be playing w/ all the buttons since I’m an engineer/scientist, so I’ll let you know.
    I think the strip method should work good for cutting. That is a good way to cut wood w/ a circular saw and should work well w/ metal IMO.
    I have purchased the student kit and the CD so we shall see. I’ll let you know.
    I saved so much cash by going with BRWelder that I bought the 625. Hope it works well and isn’t overkill. As usual, having more capabilities is never regretted. So do you keep the plasma cutting settings the same regardless of mat’l and thickness or do you back off on thin stuff to save the tips? Also which settings do you play with?
    How do you decide to choose the jig saw over the plasma cutter? Just wondering if I need the jig saw now?
    AS far as dryers go, I thought you just have the little filter/separator (I mentioned the part number in my post)?
    From the Hobart board I found this cheap-o blade grinding device from Plasplugs for grinding tungsten. Still wondering if just chucking something up in a drill will work since my space (and wife’s patience for the outgoing cash flow) is limited.
    Any idea when any of the Miller guys will be back on the board?
    Flat-out
  • HAWK
    Jerry,
    Yes, I am back up and at it. However, the weather here is cool (in the 20’s) and I am still moving slow. Congratulations on your new purchase. You will not be disappointed! Perhaps the learning curve for all the Dynasty’s features will frustrate you, but otherwise smooth sailing. Maybe you can help me when you get set up. I had thought about the circle cutting attachment, but have not pursued it. Let me know if you like it. Here’s little hint in the straight cutting: Clamp a 1” or so piece of 1/8” or 3/16” steel flat bar the required length of the cut on to your plate metal that is to be cut. Then use the drag tip on the 625 and pull or push the torch at a fairly slow, steady speed using the clamped metal as a guide for the tip to run against. Keep the torch at a 90 degree angle to your work for better cuts and less arc outages. You can also use the roller wheels that attach to the torch head (like I think you are buying). They work well, but take some practice.
    Miller has a TIG CD, but I do not have it or know anything of it personally. I have heard it is good and I am sure it would not hurt me to order and review. Face it: Technology changes and we can always learn something new. I am always willing to listen and learn from the 12 year old boy with his first stick welder to the retired 85 year old man who made this his living since WWII. Check out www.millerwelds.com under resources for the TIG CD.
    I still cannot confidently give you a thumbs up on the 375 plasma cutter. I think you’ll be happy with the 625 and have no regrets other than power requirements-not a 120v machine. The jig saw blades I use the most are the Bosch T118B and the T123X. The 123 cuts much faster, but burns up quick. It is a side set and ground blade that will rip on through the metal, but have plenty on hand! The T118B is a wavy set and milled blade. It cuts a little slower and takes a little more care in making the curves, but it is the best blade I have ever found. I mix antifreeze and thread cutting oil for the coolant. Add a few drops every ½” or so and your blades will love you lots. The Bosch T118EHM is a strip set carbide tipped blade that Bosch recommends for stainless steel. I have never used it. If you do not own a Bosch, they make most of these blades with a U prefix for all jig saws using a universal blade.
    I can no longer find the toilet paper dryers. MAC tools has an excellent dryer filter that I use on my shop compressor. It is a kit with filter and threaded base. It just goes inline with your air supply after leaving the compressor. It is made by WATEGUARD FILTERS out of Houston Texas: 1-713-450-5900. Give them a call. Let me know how it goes.
    My sincerest apologizes for dropping off for a while. As mentioned earlier, I have been sick and working like a dog,
    BEST OF LUCK
