Is it just my machine or do all Dynasty 200DXs have this little quirk?
If I move the Amp control knob too fast in an attempt to raise the amperage the display may actually move to a lower value. (During the rapid turn of the knob the values displayed jump all over the place.)
Example:
- Display reads 100 amps
- Rotate the knob clockwise at a rapid rate
- Resulting amp display may go down; example: to 50 amps
Rotate the knob counter clockwise at a rapid rate and the same thing happens but backwards; 100 may turn into 150.
(Numbers used above are contrived examples only for clarity.)
Moving the knob slowly results in correct setting increase/decrease as expected.
Example:
