bubble in weld leave pin holes
  • bubble in weld leave pin holes
    I am welding an aluminum (6061) part that is 8.75 long. I start with a tack weld at the ends on material that is 1"x.5"thick and then weld the center which is .050 thick. In the ..050 thick welding I have no problems ( I am purging the back with 100% burn through), however, when I butt weld the ends which are thicker (1 x .50) I see gas bubbles starting to escape. I try to slow down to let the bubbles dissipate but when the material is cleaned up the pin holes are still there. The material is being welded with 4043 rod the ends call out an .125 bevel , it is immaculately clean (it is cleaned with acid etch and stainless wire wheeled. The weld is not dirty it welds clean but no one seems to know why the pin holes keep forming or why the gas bubbles form.
    The machine is a Miller 350 Lx with 10 PPS and 2% thoriated tungsten is 3/32 with a glass lens.
ID:	532588Click image for larger version
ID:	532589Click image for larger version
    You might try using 4943 filler
    it seems to be a bit more fluid and is really good on 6061
    http://www.millerwelds.com/resources...Casting-repair
      Sounds like the joint is sealing, then as you are almost completing it there is pressure created by the expanding gas and it is contaminating your weld from inside the joint.
      Miller syncrowave 200 runner with coolmate 4
      and wp2025 weldcraft torch
      Miller 125c plasma cutter
        Here is a MILLER video on the subject of "Aluminum Porosity"
        it's Causes and how to avoid/minimize it...
        http://www.youtube.com/watch?v=Yu3BtdERmFM
        By Tony Anderson, Head of Aluminum Technology Miller/ITW
        Here is the updated literature he referred to
        http://www.hobartbrothers.com/downlo...minumGuide.pdf
        Porosity starts on page 24 of the flyer (page 26 of the pdf)
          Welcome to the forum Artfusionwelder.
          Lincoln A/C 225
          Everlast PA200
