If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Need help hooking up Air-Cooled TIG torch to Miller Pheonix 456!
I have a Weldcraft TIG torch and a Miller Pheonix 456..........how do I put the two together? Its gotta be pretty simple but I cant find any other help on the web
I hope that the torch you have is one with the built in gas valve...
because I am not seeing a gas solenoid on the Phoenix... I could be wrong..
you wll need a powerblock to connect the torch to the Phoenix
it is a 45V62 200amp for a large air cooled TIG torch that has the integral power cable built into the hose...
Pretty self explanatory... it connects to the welder power stud... one side threaded for the fitting on the torch... the other side accepts standard argon gas hose fitting that goes to regulator and gas bottle..
What I do, is merely get myself the dinse or reg camlock connector that goes into the machine and a tig block. Then I braze the 2 together. Easy peasy.
