DC CONVERSION
I own a MM175 and would like to know if anyone knows about CONVERTING it, or any other DC arc welder, to a TIG welder by adding an air-cooled torch, Argon reg/flow meter, and tank ? It will be restricted to welding steel, stainless and scratch starts with a copper strike plate. Will I have to use an SGA 100 ? Or can I connect a DB 17v122 or DB 1712 RDI directly to my MM175 ? Would using the MM175 void my warranty ? I plan on occasionally TIG welding 4130 steel tubing. Thank you for your responses.
