Is it possible to hook to welders together to air arc?
  • Is it possible to hook to welders together to air arc?
    I have heard that it is possible to hook 2 dc welders together to air arc does this work? Would it work to hook 2 xmt 350s together to air arc? would that be harmful to the machines? Would they be back feeding to each other? Thanks Jerry
    Miller has a booklet on paralleling power sources...
    http://www.millerwelds.com/pdf/Paralleling.pdf
      Welcome to the forum still learn'n.
      Lincoln A/C 225
      Everlast PA200
        not 100 percent sure but I would think 1 xmt 350 would burn a 1/4" rod? just don't turn it up to its max. maybe cruiser will chime in here.
          air arc is VERY HARD on inverter machines. I would not do it very often with an XMT!
            Why it is hard on inverters?
            MillerMatic 251
            Maxstar 150 STH
            Cutmaster 42
            Victor Journeyman OA
              They heat up and the digital readout goes wacko and after a few minutes you seem like you are running on 1/2 the amps then where you started. Saw it everyday when the smart people where i used to work "scrapped" all of our old 500 amp transformer machines and went with cubes of inverters. They just would't cut it...Bob
                Thanks for the welcome! We have done it off and on for a while now and havnt noticed any problems! We only have single phase power so that is why I was wondering about hooking 2 together. Sorry for the ignorance but what would be the biggest transformer style machine that would be able to run on single phase? thanks for the replies! Jerry
                  See you only want to turn your local control to 3/4 while gouging. You'll still get full output but the boards in the machine need to know whats going on. And yes if you do overload the machine output will drop in half. This is to protect the machine from nuking itself. This applys to ALL machines while gouging or running too heavy, be it transformer or inverter based.
