Miller 330 A/BP won't strike arc without dragging tungsten on work
    It's the capacitors
    Originally posted by NHTIG View Post
    Check the capacitors..which I am sure is your next step.......
    OK, thanks to some great troubleshooting tips from NHTIG, I've found out I've got a failed high frequency capacitor. He told me how to isolate the bad one so we could still use our machine, at somewhat decreased capacity, until I can get the new parts in there. I'm just going to replace them both. Seems like it's probably time. Many thanks to NHTIG. He's got my vote of confidence!
      Glad you got it figured out...
        No problem, we are all here to help when we can. Thanks for coming back in here and letting people who have been trying to help know what the outcome was. Now when someone else is troubleshooting a similar problem they will know what the outcome was. All who have been trying to help here appreciate knowing what the problem turned out to be.
          how can you check the HF capacitance
            Checking the capacitance of the high voltage capacitors is an exercise in futility. The capacitance can be fine at the couple volts the tester puts through it, yet turn into essentially a direct short at a kilovolt as it arcs internally. High voltage RF capacitors are so cheap, they should be replaced at the first sign of trouble.
            • #21
              I want to say thanks in advance for all of the knowledge that is shared here to help diagnose certain issues
              my syncrowave 300 is experiencing an issue in this range of discussion
              On DC, it all works fine using a lift arc start
              when I turn on start HF I begin with a decent arc at around 3/8” to the work, then turns off around 3 seconds
              As time goes on, the arc begins to get shorter until it finally goes away and I have to go back to lift arc
              i never check to look at the arc of the points during this time to see if they were becoming weaker
              I just got off the phone with a miller tic technician and the next move would be to check the transformer
              He suggested a voltage meter on each end but didn’t mention 3 thousand plus bolts so I’m glad I seen this post
              Not sure if I have a meter that high, but I have remnants of two X-ray defractomizer machines that could pump up to 50,000 volts
              There is a good chance I have one
              I am going to relocate the relays and am trying to reroute the wiring that is a true rats nest
              I am trying to read the schematic but am having big issues understanding some of the routing, since somewhere along the route, I have developed a dead short that pegs the voltage meter
              I have HF on both start and continuance, but the start is not timing out, plus the short
              Im hoping maybe someone here could lend a hand, the schematic is C-04602
              Im ordering a PM-350 tech manual tomorrow, off of the JD prefix stickers on some of the components
              I was unable to locate the serial number
