I am using a Bobcat 250 and Miller 12vs suitcase with inner shield. I know I need to run DCEN CV and I can set the switch on the suitcase to CV. When I put the Bobcat into DC- mode, does it automatically run CV (to match the CV on the suitcase?). If not, can someone please tell me how to set the Bobcat on CV mode? Thank you. (Welding on carbon steel 3/8" structural staircase parts in the field).
Bobcat 250 with Miller Extreme 12vs suitcase
I'm willing to say you're not right on your machine set up and it would depend on which generation Bobcat 250 you have as to the exact arrangement you're looking for. However, the DC- and DC+ mode settings are for stick/TIG (CC).
Got a unit SN?MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
Do you have the 12VS connected to the negative terminal (Ground) of the Bobcat? Your work clamp will come off the positive terminal. That's the way I use it on my Trailblazer.Lincoln Vantage 400
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic 350P Aluminum
Millermatic® 252
Syncrowave 351
Lincoln LN-25 Pro
Multimatic™ 200
XR-Aluma Pro Gun
Diversion™ 180
Spectrum® 625 X-TREME™
Thermal Dynamics® Cutmaster® 52
Victor Oxy/Acetylene Set
I had a problem running my suitcase with my TB325 after running it on my TB302 the day before. called miller and got some unbelievable good info from the guys at miller. so if you have a new 250 the way your leads are coiled may be your problem.TB 325
TB 302
dynasty 200sd
spoolmatic 30a/wc24
suitcase x-treme 12vs
miller 211
evolution rage 2
What I do...
I use a 12vs on a Bobcat225 with Esab coreshield 11 near daily. I have the bobcat set on V (not sure if the 250 has this). The +terminal is connected to the suitcase and the negative to the vs lead and ground. I find it a treat to weld with, hope this helps.
If you don't have a volt option maybe yours is not a CCCV unit? Might need to consult the manual.
Nick
8VS hookup to Bobcat
OK, I confussed. Ive been running solid wire on my suitcase 8VS with the following hookup---Course adjust V17-28, Weld process Wire +, Work clamp to work, electrode lead to suitcase. Is this right? someone above has it the other way??
Originally posted by Glidertow View PostOK, I confussed. Ive been running solid wire on my suitcase 8VS with the following hookup---Course adjust V17-28, Weld process Wire +, Work clamp to work, electrode lead to suitcase. Is this right? someone above has it the other way??
