Can MM212 spray transfer?
  • Can MM212 spray transfer?
    My new welder, MM212, should be in today and I'll have a few choices to make when I go get it. What I need to decide is, do I want 75/25 or 90/10? The lws has both in stock. I've never done spray transfer but I've read the 90/10 would be needed to do it. Is my machine capable of doing it? If my 212 doesn't have the power, then there is no sense getting a gas that may make it weld that much harder, it may just make it harder for me to not burn through things.
    My guess is that it would have marginal arc voltage for spray...
    but here is an interesting discussion on it..
    http://www.millerwelds.com/resources...ht=mm212+spray
    There are quite a few gas mixes suited to spray arc...
    here is a thread that has some good gas info links..
    http://www.millerwelds.com/resources...hlight=praxair
      I think you would be able to get that "spray hiss" and appearance, but not the duty cycle and penetration....
      Life is to short for cheap tools.
        A TRI MIX OF ARGON / CO2 / 02 will allow you to short circuit or spray. most supply houses have it.
          yup there are a great variety of mixes at different proportions that will support spray on mild steel..
          Any one in particular that you really like??
            75/25 and call it a day.
            Why do you want to Spray?
            "Because of this heat and the size of the weld puddle, spray transfer is somewhat limited in welding positions. The heat and size of the weld puddle also limits spray transfer to material 1/8” or thicker. Welding steel with spray transfer is usually done in the flat position, and the horizontal fillet weldposition. Horizontal position spray arc welds are lap and T- joint fillet welds.
            Ed Conley
            MM252
            MM211
            Passport Plus w/Spool Gun
            TA185
            Miller 125c Plasma 120v
            O/A set
            SO 2020 Bender
            You can call me Bacchus
              Broccoli1, I'm not neccessarily sure I do want to spray. I'm fairly new to welding, but think I'm off to a good start, so I am buying "the best equipment I can afford " and want to keep my options open. I really don't know much about it or why it is better/worse then short circuit, but if my welder is capable of it then I may want to try it to see what I think about it. I'm not calling you out, but from your reply I get the idea that you don't think much of it. That's cool. It seems like some on here find it has a useful purpose. I'd like to form my own opinion.
              I asked today at our lws and they only have the 75/25 or 90/10 right now. I'm not sure what else they can get in, but if my welder comes in today I'd like to pick up my wire and a bottle and be ready to make some sparks!
              Thanks for the replies and info. H80N, I really appreciate the links to more knowledge. I'll probably have time to read through that tonight.
                It's not that I don't think much of it but to get rolling you should just get the 75/25, wire- hit the local steel yard for some scrap or cut offs/remnants and start welding.
                Spray is limited to a Flat position- Not very useful for us home geeerage types.
                After you burn through the roll of wire or a couple then move on to playing around with Spray.
                The MM212 comes with a chart for 75/25 gas, straight CO2, Tri-Mix for stainless and Argon for Alooominum.
                Ed Conley
                MM252
                MM211
                TA185
                O/A set
                SO 2020 Bender
                  Based on the information Miller is supplying on the V/A graph for the MM 212, go with C25 shielding gas. The MM 212 doesn't look like it's going to have enough top end voltage for spray arc, especially with 90/10.
                    Ed,
                    My Wife's little Kubota tractor with a front end loader (bucket) can easily fit our garage, and assist in repositioning parts when needed.
                    My 6' 205lbs 17 year old Son comes in handy for helping reposition parts too.
                      Spray is pretty much useless unless you have both an industrial machine (which you don't), and a real need for it, otherwise keep to short arc. Get a bottle of C25 ( 75/25) and then weld away.
                        I had my 211 set up doing SS and it was spaying. then I gave it just a little more wire. welds came out awesome . and it was a 1/8 tank no warping.
                        TB 325
                        TB 302
                        dynasty 200sd
                        spoolmatic 30a/wc24
                        suitcase x-treme 12vs
                        miller 211
                        evolution rage 2
                          As long as you have a gas that has a high enough percentage of ARGON to support spray RELIABLY and your machine will crank out enough power to spray, then you likely CAN do it. What I have found to be the main roadblock is that the gun provided with most machines that "can" do spray when cranked WAY up (where you will likely be pushing the machine pretty hard) will be SMOKING HOT when you are done with any spray weld that is longer than about 5 seconds. If your machine will support extended periods of spray, be sure that the GUN can handle it or you will smoke it every time you do any amount of spray.
                          And like someone above said, spray, while it is kind of neat and does produce a nice looking weld, is rendered fairly useless in any but the flat welding positions due to how highly liquid the puddle tends to be. That said, I DO use spray sometimes when I can use the flat position and am welding fairly thick stuff AND want a "pretty" weld. The one big advantage to spray seems to me, anyway, to be that it is pretty darned spatter free. (not to mention that it sounds pretty cool!)
                          Don J
                          Reno, NV
                          Never pick a fight with an old guy. Old guys are too smart to fight and get hurt. They'll just kill you and get it over with.
