having problems with my gas flow on an xrs controller.
  • having problems with my gas flow on an xrs controller.
    The machine will feed wire and flow gas. But after a second of holding the trigger the gas stops. I have switched leads and regulator, still does not flow gas constantly. I have reason to believe its the motherboard. Anyone have experience repairing welding machines?
    Thats a second of welding, or just holding the trigger, cause gas will shut off if your just holding the trigger and not welding.
      I test it on scrap aluminum and cleaned with acetone and the weld looks dirty when welding. You can tell its not washing ahead of the puddle. I then continued to test the regulator and leads. Still dirty. After testing it while welding a few times i just held the trigger and you can hear it stop the flow of gas. I swapped controllers and im running again just fine.
        Probable reed switch inside the controller not telling the machine that it made a contact (welding) The power cable from the power source must pass through a square thingy before it attaches to the drive.
          I will follow up and try that out. Thank you
