I know that I'm just a beginner, but I'm getting tired of seeing a pretty "puddle" of shinny aluminum all of a sudden turn dirty. What be used mechanically and chemically to avoid contamination?
Thanks,
García
For mig and AC tig I use a stainless wire rope brush on a grinder to brush off the surface and it works just fine. If you are welding Al with DC and He you will need to go with a chemical cleaner as JWELD suggested. Chemical cleaners work well all around. I don't use them if I can get by with a stainless brushing. Ask you dealer for a good chemical cleaning product.
Hawk: I'm using a Syncrwave 180 sd. Using a cleaning solution that has HYDRFLOURIC ACID and PHOSFORIC ACID plus some "Surfactant" I have also tried using a S.S. brush. I keep on getting mixed results. Some pretty clean weld spots, and some dirty ones.
Greg: thanks for the suggestion. If I have been able to stand the smell of formaldahyde, I can live with acetone. I'll give it a try.
Thanks,
García
You say you're getting mixed results. Are you cleaning just prior to welding? Best results will be achieved by welding promptly after cleaning. Surface oxides reform quickly. You might try a good stainless brushing (hand brushing is not always effective)try a grinder with an ss rope brush. After brushing wipe down with isopropyl alcohol. It evaporates quickly. Then weld.
Again, I have great sucess with the comercial cleaner from the distributor. Clean the metal, stainless steel brush it then use the "cleaner", Then I use very hot water and blow dry. If that does not work, I would throw the part to be welded away.
I've had mixed resulst as well, I think its due to some of the small scrap pieces that I get from the local surplus place. Just low quality Alum.
Justin Starkey
Syncrowave 250 TIGRunner
Miller 210 MIG
Spectrum 375 Plasma
Ford and GM Dyno-tuning on the Moblie Dynojet trailer I built. VMP Tuning.com
Seeing that you stated that you are a beginner, I just want to make sure you have torch angles right and gas flow rates correct. Some people think as long as there is an arc flowing, it should weld. Not true! Torch angle is critical and just the right amount of gas flow. Too much flow will cause turbulance and too little will not shield properly. Try a 5 to 15 degree torch angle pushing the torch. Never pulling. 18-22cfh on the flow with the standard Sync180 torch should do for gas.
