just bought a new mm252, having gun issues
  • just bought a new mm252, having gun issues
    just above the nozzle sits a plastic ring that covers the upper end of the nozzle, crank up the welder and it melts, miller is aware of this, their responce, yep it does melt when the machine is pushed, pushed they say, i say used as designed, any one else seen this happen
    I have melted bags of them in the last 2 years. Anything above 24V and she will melt. So i stay 23.3 and zero problems. I also use nozzle dip that's half dip and 1/2 water. I use mine 9 1/2 hours a day everyday...Bob
      Thats some good info, I still have not pushed my unit, but I do not use it to make a living. As allways good info to have.
        shock collar I believe its called. really just another consumable in my book. just like tips. buy a bag of them and get over it. I think there about a buck each.
          bob, do you have any problems taking the gun apart to put the collar on, its a crazy set up, brass, copper, fine threads close to .75" long. my gun came apart real hard, i can see issues here down the road, is this a problem, taking it apart after a while. thanks. kevin
            bob i need to type fast,the forum times out after a few minutes when i reply??????????. wouldnt you think miller would do a better job with the gun, the welder is great, sprays real nice, except the gun melts??????????
              Talk to your dealer and see if they'll help you into a better gun.
              Syncrowave 250DX
              Invison 354MP
              XR Control and 30A
              Airco MED20 feeder
              Thermal Dynamics Cutmaster 81
              Smith O/A rig
                Yes i do. The fine threads will strip off. I do use neverseeze too. I have stripped the necks on 2 guns and just dug thru the dumpster a few days ago and found a donor neck to swap out. Told the buyer to order me 2 spare necks as they are simple enough to replace...Bob
                  I had similar issues with mine, but also after a few years my gun seemed to just be falling apart. I needed a new liner for my cord so ended up just getting a whole new setup off e-bay: http://www.ebay.com/itm/HTP-Miller-1...item2ecb7f941c
                  That gun itself is made much better and solved all my issues. It uses all the same consumables as the factory m-25 gun. I haven't melted the shock collar yet but since it's the same I probably will, just haven't welded hot enough with it yet.
                    I switched to a Bernard Q gun and in my opinion it is a much better unit. I saved my M-25 for a backup gun. A good welder such as the 252 deserves an equally capable gun.
                    Nick
                      252
                      I bought one of those for the union hall for tacking coupons up, I just hate the stock gun, I bought a tergaskiss 300amp gun and the machine is a whole new monster.
                      I just hatted this welder before, spatter would not feed very well....
                      Changed the gun and bam that machine is great nice and smooth....
                      Just my $.02
                      Railmen
                      2007 Trailblazer 302G
                      2004 Invision 354MP
                      1999 60 series feeder
                      2005 Maxstar 200DX
                      2007 CST280
                      1999 HF 251-1
                      older Hobart hefty wire feeder
                      Hyperthrem 600
                      Maxstar 150S(such a cute welder)
                      had and sold........
                      2003 XMT 304CC/CV
                      1947 Lincoln SA200G short hood
                      1963 Lincoln SA200G
                      1975 Lincoln SA200G(best machine ever had )
                      1970's Lincoln SAE400G
                      2 Maxstar's 200DX's
                      1 Maxstar 200SD
                      CST 280
                      2 CST 250
                      MM130
                      Railmen
                        When I had my 252 I changed the gun out to a q300 also. They can be had new off of eBay for less than $100 if you watch the auctions.
                          gotta tell ya, Miller is the best of the best in welding equipment, their equipment is top shelf and their service is equal, I explained to my rep the down falls of the gun that is supplied with the welder, i compared it to driving a rolls royce using a pinto steering wheel. my local rep talked to miller, explained my case, they swapped out a bernard q gun. they stand behind their people, service is huge,
                            i need to type fast, my computer times out on this forum, dont know why. i have been buying miller since 1986, over 10 welders, any issues that i had were always fixed with a phone call, then a hand shake. their service is the best in the industry.
                              When our shop had to replace two mig units due to theft we stayed with the 252s. Originally we had a 251 and a 252 on hand. When the two new units arrived from our LWS both were equipped with Bernard Q guns. There is no way the factory guns would hold up at all to the sessions of high heat and volume we put them through. If you are going to run the machine at higher settings for long periods of time just get a quality gun and burn away. Now I want to set one up to run aluminum and see how it does.
