Water-cooled tig torch conversion fail
  • big mike
    Glad you got it fixed......just shows how the small stuff can trip you up.
    Are you going to cover the power connection on the side of the machine.....hate to see someone get zapped.
  • H80N
    Originally posted by mx_racer428 View Post
    BINGO!! Chinese collet was to long and the gas lense was not getting a proper seal. Thanks for all the help guys!
    VERY COOL...!!!
    sometimes it is the simple oddball stuff...
    Glad you got it sorted out....
  • mx_racer428
  • MMW
    It sounds to me like a gas issue. Whether you have coolant flowing or not shouldn't affect the arc to test it. Yes after a short time it will over heat but just to test it out it won't matter. Unplug the dinse & try blowing through it to make sure it is free/open. It could be a blockage but you said gas comes out so maybe a leak that is drawing in air to the gas?
    Just to clarify when you change to the aircooled torch it works fine on the same material?
  • cruizer
    Only thing that would be wrong on the plug when hooked up backwards is the fuse protection to the unit, as if it is backwards there wouldn't be any protection.
    Otherwise the motor will only ever run in one direction.
    Its ONLY on 3 phase applications that we can make the motor run in the opposite direction
  • mx_racer428
    Cruizer has a point....
    pretty easy to get those two lines flipped with one of those adaptors...
    AND with the Miller absorption of Weldcraft....
    ALL of the online hookup diagrams seem to have disapeared...
    my reference links to weldcraft have gone dead and been intercepted by a useless Miller page??... NOT Optimal...
    With the adapter (miller) I have you can't hook the power/return like up wrong. As the return from adapter to the cooler that could be but if fallowed both feed and return lines and they are in the correct spot, I am curious if the cooler has a reversible motor in it for the pump and maybe the 3-prong 120v plug is wired in reverse since it's not the original plug. I am going to the welding shop tonight to pick up some non-china torch consumables. Try and rule everything out. Thanks for all the tips and suggestions so far. This is a great comminty.
  • mx_racer428
    1/8" purple and also tried pure with no change.
  • H80N
    Originally posted by cruizer View Post
    Quite l ikely that the torch is hooked up backwards. The current carring conduit is the return line. The torch head is what must be cooled first. Its the other way, the conduit is cooled, however the head gets way hot and trouble happens shortly after.
  • H80N
    I also tried raising the argon pressure too because it's acting like low gas flow or none at all but raising the pressure didn't change a thing. You can clearly hear and feel the argon flow coming out of my gas lense.
    try switching back to a standard cup and collet configuration to match the tungsten size you are using...(US Made name brand) one less variable
    speaking of tungsten... what size, color code and make??
  • cruizer
  • mx_racer428
  • mx_racer428
    Running esab torch coolant, torch is new/untested. Water and power leads are hooked up correctly. The torch it self is a CK swivel head.
  • H80N
    I would ask what coolant fluid you are using??
    water?
    distilled water??
    premixed low conductivity TIG coolant??
    car antifreeze??
    would also ask the brand and model of water cooled torch and collets... some of the soft chinese copper collets can crush and restrict argon flow.... leading to symptoms you described...
  • big mike
    I can't see clearly if they are hooked up this way but I believe it should be,
    Red(power cable) into the back of the Dinse
    Red from the Dinse to the cooler
    Blue to the cooler
    Black to the Dinse
    Are you sure you don't have a bad power cable?
  • mx_racer428
    I was thinking since I have the return-water and to-water bolted to the machine that it was grounding out. I unhooked them from the machine with no change. Next I'm going to separate the return and feed/to water from each other and see if that resolves the issue.
