millermatic 252 settings cards
  • ericher69
    started a topic millermatic 252 settings cards
    To the 252 owners;
    Do you find the settings charts on the front of the machine to be generally on the cold side?
    Running
    ER70S-6 wire 0.035
    CO2
    1/2 second pre-flow
    2 second post flow
    Should I be using the thickness gauge tool instead?
  • @cvmechanical
    "The free online resources that are available these days are phenomenal...
    wish they had been available when I started...
    There was no internet and the personal computer had yet to be invented or even possible"
    Same here!!! Love the present
  • H80N
    Originally posted by ericher69 View Post
    Ok thx will try these suggestions
    There was no internet and the personal computer had yet to be invented or even possible...
  • ericher69
  • H80N
    So your saying if input is 220V instead of 230V I may need to go up in voltage.
    It really is worth your while to download and read your owners manual at least twice..
    Make sure you plug in your serial number to get the correct version..
    http://www.millerwelds.com/service/o...uals.php?model
    as far as settings go... as Broc said.. they are a starting point... personal speed and style will greatly affect how much you need to adjust..
    there is a real treasure trove of info on technique and settings in the MIG resources section..
    http://www.millerwelds.com/resources...ur-skills/mig/
    a little bit of study will answer and clarify a whole bunch of your questions..
    The better understanding you have of the basics.. the better your results will be and the faster your progress in skill building..
  • ericher69
    Originally posted by johnnyg340 View Post
    verify input voltage? May have to adjust output accordingly...
  • johnnyg340
  • ericher69
    Originally posted by Cgotto6 View Post
    What length stick out are you running?
    1/4-1/2"
  • @cvmechanical
    I always go up in settings by a gauge if welding 1/4" I use settings for 3/8" and so on running .035 with 75/25
  • Cgotto6
  • ericher69
    Yup I did use the recommended settings for CO2 and noticed I needed to up the voltage.
    Thanks for the feedback
    Sorry, you misunderstood. CO2 runs hotter. Therefore it was necessary to lower the voltage.
    It may be the case for you but I've found so far the chart is cold even with CO2 therefore I've had to raise voltage
  • fire1hawk
    To the 252 owners;
    Running
    ER70S-6 wire 0.035
    CO2
    1/2 second pre-flow
    2 second post flow
    The charts are way off
  • Synchroman
  • ericher69
  • Synchroman
    Yes, straight C02 runs hotter than the settings shown on the cards. I welded some 1/2" 1018 plates on a bevel joint recently. The settings were shown as 29.5 V (basically wide open) and 5i5 IPM on wire speed. I tried that and had to back down to 26 volts add 450 IPM and that was fine with .035 wire.
    I think the settings would be very close with 75/25 gas.
