Hey there guys. I got a question i want to throw out your way. So i need to fillet weld a 4"x.5" aluminum flat bar to another 4"X.5" flat bar. The alloy is 6061t and my filler is 1/16th 5356. Ill be using a miller aluma pro with a miller deltaweld. Now the question...should i preheat this or can i just weld. The peices are about 19 feet in length. So there you go..if you need more information about this project let me know.
Should preheating be required to fillet weld half inch thick aluminum?
Bevel both sides
tack ends
Clampon a flat surface
preheat 200-300f
Weld.
Flip clamp.
weld ..
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
I would pre-heat the beginning so you don't get a cold start. Once you are burning wire you should be fine.Last edited by MMW; 11-07-2013, 07:44 PM.MM250
RCCS-14
