I just got my new 211 with the Spoolmate 100. Man am I happy with this machine. However on my very first weld with the spoolgun I toasted the tip All the way into the barrel. After reading all day it is apparent that I'm not the only one that has had this issue. After ordering another barrel assembly ($45) I discovered an article about how to drill out and retap the barrel so the normal mig gun tips will work in the spoolgun. If this is a known problem then why hasn't Miller dealt with it. It sounds like the tapered tips are the problem due to over heating. Any ideas or the modification or suggestion on how to keep this from happening. I'm kinda gun shy because of the cost to keep replacing barrels or tips. Seems to be a common issue. Thanks for the advice. TW
Spoolmate Tip Issue
You may be interested in this thread:
http://www.millerwelds.com/resources...question/page2
You can PM Bob Aametalmaster about doing the mod for your spoolmate.Burt
_______________________
Miller 211AS
Miller 375
Miller Syncrowave 250
Miller Thunderbolt XL
http://www.10FtDrillBit.com
I'm gonna send the original one to Bob tomorrow and let him modify it for me. I ordered a new barrel assembly and it should be here soon. It was strange how it happened but I think I was the cause. The autoset chart called for 50/7 and I had it set at 70/5. I had it backwards. It welded about 3 seconds and popped and stopped. After I got it working again and adjusted the settings it seemed to work fine. I like the idea of being able to use the bigger tips. Thanks Bob, its on its way in the AM.
