I have a Spectrum 701 with 2 PC boards that bad. I wanted to switch the torch to an old Spectrum 500 that still works because we have a lot of consumables for the ICE 50. Can take out the quick connect from the 701 and fit it to the 500? It looks like the ICE 50 has 1 more wire than the APT 5000 that is on the 500. I searched for wiring diagrams/spec sheet on the torch, but couldn't find anything. I know they sell an adapter but if I can swap them out with out buying anything else it would be worth a try. The extra wire was hooked up to a contact in the 701 and I'm not sure where it would go on the 500 machine. Any advise or comments would be greatly appreciated.
Can i use an old ICE 50 torch on a Spectrum 500 plasma machine
Do not know how helpful this will be...
but here is the manual that covers the ICE-50 Plasma Torch..
http://www.millerwelds.com/om/o1591b.pdf
and the manual that covers Spectrum 500 torch hookup..
Figure 5-7 on page 17 shows hookup..
http://www.millerwelds.com/om/o204h_mil.pdf
Cruizer could probably answer this one quickly if he is around..Last edited by H80N; 11-01-2013, 08:01 AM..
Thanks for the info H80N.
Originally posted by JoseV View PostI noticed the torch I have is different from the manual. Ours has the safety trigger (you have to lift then press). Anyone know if there are different makes of the ICE 50? Not sure if the quick connect plug has anything to do with it. Also has more wires than in this manual.
see if this version works...
it is for the ICE-50C and has the "Safety Trigger"
http://www.millerwelds.com/om/o1593t_mil.pdfLast edited by H80N; 11-01-2013, 08:19 AM..
You will have to make sure of torch compatability as to whether "HF" or "Pilot Arc" will have to be checked...
That could be a showstopper...
Originally posted by H80N View PostYou will have to make sure of torch compatability as to whether "HF" or "Pilot Arc" will have to be checked...
That could be a showstopper..and thanks again H80N you've been helpful
