I'm looking to buy my first tig welder and I'm looking at the diversion 165 and the syncrowave 200 and 210 anyone have any good bad or ugly feed back on these machines
Looking for my first tig
Don't waste your time with the Diversion.....find a good used Sync or Precision Tig(Lincoln).....I am purchasing my next welder in the next month. I am going with the HTP Invertig221. Great customer support and a sound machine. DaveOriginally posted by Mv7fd View PostI'm looking to buy my first tig welder and I'm looking at the diversion 165 and the syncrowave 200 and 210 anyone have any good bad or ugly feed back on these machines
Originally posted by Alumaweld View PostDynasty 200 you will thank me later
Originally posted by sky-dogg View Postdynasty 200!
Excellent TIG Machine...
nothing else comes close in the 200 amp class..
a machine you can start with.. that still has plenty of capability to grow into as your skills develop...Last edited by H80N; 10-23-2013, 09:39 PM..
Originally posted by Cgotto6 View PostWhat's your budget?MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
I started with a Diversion 165 as my first TIG. After a couple of years I found myself wanting to be able to play with different settings that are fixed or automatic adjust based on amperage on the Diversions. But I was able to sell the Diversion quickly for almost what I paid for it. You will be best off buying the machine that you are going to be happy with the longest, but that is hard to know just starting out.
Budget would be good to know. He wants a $1600 welder and you suggest a $3500 welder? I know the 200's are nice but im guessing money turned him off from that welder. I would love a 200 or 280dx tig, but money is too tight for that...MillerMatic 251
Maxstar 150 STH
Cutmaster 42
Victor Journeyman OA
Used Syncrowave
If you want a good basic TIG, without spending a lot of money, it is hard to beat a used Miller Syncrowave 180 or 200. I have owned both, both are good. Both have High Frequency, AC and DC, so you can weld any metal, including aluminum. Both include stick and TIG. The original version of the Syncrowave 180 is arguably better for beginners, as it has minimal controls, three switches and one knob, simple to use. The later version of the 180 (180SD) added an AC balance knob and digital displays. The 200 has lots of bells and whistles, including pulse, which I like for thin copper. The 180 is a little smaller, but both are relatively big and heavy, around 200 pounds. Figure on at least a 50 amp 220V circuit for either welder, which is what I use. Some recommend a 60 amp 220V breaker.
I bought the 200 for $1300, too good a deal to pass up, and then sold my Synchrowave 180 for $1150. The 180 price that I got was probably higher than average, and the 200 price that I paid was lower than average, so I did very well, paid only $150 to upgrade.
Anyway, for somewhere between $900 and $1500, you can buy a used Syncrowave 180 or 200, and have a welder that will probably serve all your needs for decades. If you buy used, and you decide you need a bigger or fancier welder down the road, you can get almost all your money back when you sell it. You will take a big depreciation hit if you buy a new welder and sell it later. With these Syncrowaves you can TIG weld any thin metal up to about 3/16 inch, and you can stick weld any steel 1/8 inch or thicker. I used the 180 as a stick welder for months before I got around to buying an argon bottle. Some report that the 180 had a higher than average repair rate, but my original version 180 gave me no trouble.
I am not a big fan of the Miller Diversion because it lacks stick. Stick is what you need to weld thick steel. The Dynasty is a great welder, but way too much money unless you have to have easy portability, or need 110V. (Note that a 20 amp 120Volt outlet will only run a welder at very reduced power, so 110V operation is not that great an advantage). If you need portability, you could consider a Thermal Arc 186 AC/DC, maybe half the price of a Dynasty. The Miller EconoTIG looks good on paper, but a Miller factory guy said that it was not that great, that the Syncrowave 180 was a much better machine. Lincoln makes the Square Wave 175, and Precision TIG 225, similar to the Syncrowaves, look for a used Lincoln as a possible alternative. The Thermal Arc 185 or 186 AC/DC are possible alternatives, inverter welders at reasonable prices. Many if not most inverter welders are DC only, so you can’t TIG aluminum. (Examples: Multimatic 200, XMT series, Maxstar series, the new Thermal Arc multi-process welders, Lincoln V350 and C300, etc.) The Chinese machines from Longevity and Everlast have an attractive price, but resale value, reliability, and support are concerns.
Note that many inverter welders, such as the Dynasty or Invertec series, do not come standard with a TIG torch, regulator, and foot pedal, so they are even more expensive than they look at first glance. The Syncrowaves come with everything you need except a gas bottle. The welder manufacturers are pushing their high end inverter machines, but it is hard to justify the much higher cost, especially when you can find a used Syncrowave for not much more than $1000. They have sold a lot of Syncrowaves, so you should be able to find a used one if you look.
Just for comparison, a new Syncrowave 200 retails for $2900, a new Syncrowave 210 retails for 3200, a new Dynasty 200DX with torch, regulator, foot pedal, etc., retails for $5100. On the used market, the Dynasty 200 welders are hard to find, and priced around $3000. The Syncrowaves are easier to find used, and priced right.
The Syncrowave 250 is an industry classic, a great machine, but big and heavy, and more expensive. It should probably have a 100 amp 220V circuit, especially if you want to get full power out of it. The 250 is just more welder than most folks need, unless you need to TIG 1/4 inch thick aluminum.
Richard
Originally posted by Mv7fd View PostI'm looking to buy my first tig welder and I'm looking at the diversion 165 and the syncrowave 200 and 210 anyone have any good bad or ugly feed back on these machinesSyncrowave 200, Millermatic 211, Victor torch, Propane forge....
What makes Invertigs crap? They are a cleaner, more affordable machine that puts out more max amps and a higher duty cycle with more options and HTP has second to none customer service. What is your support behind the statement? Do you repair HTPs also? DaveOriginally posted by cruizer View PostOK, the Invertigs are crap, I do lincoln warranty. Miller 165/185 are great, but I'd be looking at a Thermalarc 186TS or 201TS. Somewhat less expensive and longer warranty. Easy to learn on.
I amy be a bit naive after only having used their migs but it is difficult to find any bad comments about HTP besides yours. DaveOriginally posted by cruizer View PostOK, the Invertigs are crap, I do lincoln warranty. Miller 165/185 are great, but I'd be looking at a Thermalarc 186TS or 201TS. Somewhat less expensive and longer warranty. Easy to learn on.
Misspelling...i think.
JerseyWelder JerseyWelder is offline
Member
Join Date
Aug 2013
Posts
35
Default
Quote Originally Posted by cruizer View Post
I think he meant invertec from lincoln, never he mentioned HTP...
Cruiser, more than a year ago recommended to another poster a thermal arc plasma , that was enough to make me buy one, i am extremely happy about it;o)
