Aluminum Wire Question
  • Aluminum Wire Question
    What's the difference in 4043 and 5356 wire. I need to weld up a heavy duty Jon boat. Which wire should I use. Thanks for any advice.
    With aluminum there is different compositions, just like with steel there is low carbon, medium carbon (a 36) and high carbon,. You need to figure out what type of aluminum you'll be welding and that will tell you which wire to use… if you use the wrong wire your weld will break right down the middle
      I do a lot of aluminum work and I never really looked at the wire I use. I took a look a few minutes ago and I have been using 4043. I weld tool boxes and I also do boat repair with it and never had any problem with it.but i'm with you on this one and would like to know if you have to match the wire with the plate or if it even matters?
        Aluminum Welding Guidelines...
        Maxal Aluminum Welding Handbook..
        a really good overview for TIG and MIG
        including setup, parameters for different alloys and GOTCHAS...
        http://www.maxal.com/files/QuickSite...g_6-11_doc.pdf __________________
          In a nut shell,
          4043 has a much higher silicon content which results in improved fluidity (wetting action). it is also less sensitive to weld cracking. Very easy to work with.
          5356 has lower silicon which makes it a little more difficult to work with, but much higher magnesium content which produces a stronger weld.
          JIM
          Owner Operator of JNT Mobile Welding & Repair LLC
          Millermatic 350P Aluma Pro
          Maxstar 150 STL
          Trailblazer 302
          Suitecase 12RC
          Extreme 12VS
          Extreme 8VS
          Spoolmatic 30A
          Miller HF251D-1
          Passport Plus
          Spoolmate 100
          Hypertherm Powermax 45 and 85
          Ingersoll Rand Engine Driven Compressor
          Dake 75 ton H-Frame Press
          JD Squared Model 32 Bender
          Miller Digital Elite
            I'm not a boat expert, but most boats that live in a salt water atmosphere are probably 5356 which offers better corrosian resistance.
            4043 is a little easier to work with smooths out better while 5356 is more of a structural wire for strength.
            I'm not sure what a john boat is but I have fixed alot of small aluminum boats that are in fresh water small lakes with 4043
              Maybe this will help
              JIM
              Maxstar 150 STL
              Trailblazer 302
              Suitecase 12RC
              Extreme 12VS
              Extreme 8VS
              Spoolmatic 30A
              Miller HF251D-1
              Passport Plus
              Spoolmate 100
                aluminum wire
                I use 5356 on anodized aluminum or aluminum that is not new. It welds awsome on aluminum that needs alot of cleaning action. If your going to anodize the aluminum 4043 is your ticket. Hope this helps. Good luck
                  Huh? Anodize 4043.
                  HH 210MVP
                  Spoolrunner 100
                  Powercraft AC buzz box
                  Lotas LTP5000D plasma
                  Victor Oxy/Acet
                  30 ton press
                  A few brand name tools
                  Lots of no name tools
                  A wife to worry me
                  and 4 dogs to supervise me
                    You don't want to weld anything that's going to be anodized with 4043, the weld will come out very dark, a piece that will be clear anodized, the weld itself will be almost black. Use 5356 alloy only.
                    Miller 350 LX Tigrunner
                    Miller 350P w/XR-Pro
                    Miller 250MP w/30A spool
                    Miller 211 Autoset
                    Hobart Tigwave 250
                    Hobart Beta-Mig 251
                      Just so you know most aluminum boats are made from 5083 or 5086 and welded with 5356.
                      Miller 211 Autoset
                      Hobart Tigwave 250
                      Hobart Beta-Mig 251
                        Thanks for all the great information. The boat is a salt water version. SeaArk. I might give them a call and see what they say. Thanks again, TW
                          OK, the folks at SeaArk said they use 5052H aluminum. Any ideas????? I tried one spot and what I have seems to be working fine. Thanks
                            According to the Alcotec chart, 5356 offers improved strength and ductility over 4043 when welding 5052 to itself, but the corrosion resistance of 5356 is not as good as 4043. Always trade-offs.
                            Mike Zanconato
                            Zanconato Custom Cycles
                            @mzank on Instagram
                            Dynasty 280DX
                            Meco Midget
