I have a Lincoln SA200 1975 that was welding ok (kind of cold by the settings). It stopped welding and now it has 109 volts on the AUX with no weld output.Where should i start? Thanks
- Failed local or remote rheostat,
- Failed remote switch
- failed generator or brushes to comutator, one of the 2 blue wires from the generator has broken
