trouble finding where to buy bobcat service manual
  • trouble finding where to buy bobcat service manual
    I have a miller bobcat 225g.
    It apparently has a problem with fuel flow.I noticed that the fuel filter is only less than half full while it struggles to keep running.
    I dont want to start taking it apart without a manual.
    Do I get a manual for the onan engine? Or is ther one for the whole machine besides the owners manual?
    Thanks. I love this website!
    Gummed carb??
    First thing to do is download the owners manual for your specific version of the Bobcat 225G...
    that is done by plugging in your welder serial number here...(free download)
    http://www.millerwelds.com/service/ownersmanuals.php
    this will tell you which engine you have...
    probably a P216... but better to double check..
    if it is a P216 (or that family)
    here is a link for FREE PDF download of the Engine Service Manual..
    http://www.cumminsonan.com/www/pdf/manuals/965-0762.pdf
    sounds like maybe a gummed carb and filter...
    I would drain the gas, replace the filter and put in fresh gas with some carb/injector cleaner and run it to loosen the gum..
    Probably some of one of those spray carb cleaners down the intake and let soak would not hurt either....
    There is a lot of varnish in modern gas...
      For engine problems you want an engine specific manual usually not available through Miller. I got mine off ebay reasonably priced. Make sure you get all the numbers off of the engine itself. There should be a tag somewhere on the engine.
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Lown 1/8x 36" power roller
      Arco roto-phase model M
      Vectrax 7x12 band saw
      Miller spectrum 875
      30a spoolgun w/wc-24
      RCCS-14
        Or download it for FREE from Cummins-Onan....
          The "half full filter" itself is not a problem.
          Griff
            Here is a thread on that problem that might be helpful....
            http://www.millerwelds.com/resources...ler-225-g-carb
              Fuel line crack
              Fuel pump issue
              Carb float or jets.
              Try gravity feeding it fuel by using a small tank held above the carb. Problem gone then check the fuel lines and pump.
              Problem still there then it's in the carb. Haven't been into mine yet but starving can be a plugged jet or a sticking needle valve.
              The suction line on mine inside the tank had a small crack in it about half way down. Would run great with a full tank then start to stutter as the level dropped. Took a while to find but an easy fix.
