I have looked thru most of the posts here and have not really seen what I was looking for. Here is the question: Can a MM175 or MM210 be used to weld Aluminum w/o the spool gun? A friend and I were talking at work last night and we were wondering if you could basically run one of the MillerMatic's as an Aluminum mig welder if you were going to weld mostly Aluminum? Or would it just be best to go with a TIG machine?
While I am at it, what is the thinnest Aluminum material that you would use a spool gun on? What would be a good TIG machine to get? I use to work for a company that built petroleum and dry bulk tankers and 85% of the welding I did was AL TIG, but that was 12 yrs ago.
As always, thanks,
Mike
As always, thanks,
Mike
