I have a syncrowave 250 dx. I'm running on dc- every once in a while when I press the peddle to strike an arc my arm that is resting on my work bench will get shocked. It's extremely annoying and I can't figure out why it does this. It doesn't matter whether it's my torch arm or the other. And it's very random. I can't seem to find a pattern. Does anyone know what might be causing this?
getting shocked
I got popped a couple times the other day, not the first time by a long shot.
If things are damp, that seems to light me up. But the other day I just moved the ground right up next to the work and it didn't happen again.
Good gloves go a long way but won't always prevent it.
I did notice once that the arc was coming right out where the tungsten cap screws down onto the torch. The components seemed ok but that's where the arc would jump out.
good gloves, keep dry, keep a good ground close to work. If all that fails set some wood up to prop on.
It's the high frequency on start up. Wear proper PPE (personal protective equipment) make sure you have a good ground and your equipment is in good repair.Miller syncrowave 200 runner with coolmate 4
and wp2025 weldcraft torch
Miller 125c plasma cutter
X2 on the high frequency. If you are sweating and gloves get damp it will get you every time. My hands sweat alot so i use seperate gloves for grinding handling etc and then a pair just for actual welding. If it bothers u that much and u are weldind steel u can turn the hf off and scratch start.
Originally posted by ryarelliott View PostI have a syncrowave 250 dx. I'm running on dc- every once in a while when I press the peddle to strike an arc my arm that is resting on my work bench will get shocked. It's extremely annoying and I can't figure out why it does this. It doesn't matter whether it's my torch arm or the other. And it's very random. I can't seem to find a pattern. Does anyone know what might be causing this?
ask any TIG welder... getting zapped comes with the territory...
even more exciting during the sweaty summer months....
you might try and move your ground (work clamp) directly to your workpiece or as close as you can get it tho shorten the path... that might help some.(as said before)
you might do a search... there have been a lot of threads on it..Last edited by H80N; 09-25-2013, 01:34 PM..
