Iim a weldor not a mechanic
  • Iim a weldor not a mechanic
    This is my first experience here. I am hoping to find help with my welder problem.
    my bobcat 225g has trouble starting then stalls in a couple minutes.
    I thought installing a tune up kit would help, but it didnt.
    The kit included all new filters and spark plugs.
    the hour meter shows 1366.
    I am not a mechanic so I dont know what to do.
    I bought this used machine 11 months ago,and I am depending on it to do side jobs with. Any tips would be much appreciated
    Has it been sitting for a while? Maybe try to change out the gas and clean the carb.
    At home:
    Millermatic 211 Auto-set
    Spoolmate 100
    At work:
    2-Syncrowave 250
    2-maxstar 150
    millermatic 250X
      Fuel Air Fire. Start with that.
        Take the bowl off the carb and make sure float/needle are not stufff. Remove the couple small brass jets and make sure u can see daylight through them. Dave
          As is always best when asking for tech info please provide serial # of unit.
          When cranking over can you smell gas? Are the plugs wet? This would mean your getting fuel. If it starts & dies out shortly maybe the fuel filter is clogged or the pump is getting weak. (is this one of the filters you replaced?)
          Have you checked the spark? Do you have any when cranking it over? Have you checked the points if it has them? If you are mechanically inclined I would buy a service manual for your engine. They can be found on e-bay or else ware.
          By the little info you've given it sounds like a fuel issue but?
          MM250
          Trailblazer 250g
          22a feeder
          Lincoln ac/dc 225
          MM200 black face
          Lown 1/8x 36" power roller
          Arco roto-phase model M
          Vectrax 7x12 band saw
          Miller spectrum 875
          30a spoolgun w/wc-24
          RCCS-14
            I am looking for a engine drive but would go propane just because it of the fuel issue.
            But your problem could be spark related to even a bad key kill switch (not in the engine at all). Figure it out.
            But don't go ripping a carb apart for the first time without supervision if you have no experience with such things.
              All the suggestions above are good ones but the saying in the fire and Ems system is "First do no harm". Please don't tear the bowl off the carb with out someone being there with you that has knowledge enough to help. One person had it right, fuel, fire and air.
              Fuel- A. Fresh fuel
              B. Replace filter.
              C. While you have the line unhooked check to see you are getting a full stream all the way to the carb.
              Fire- A. New plugs properly gaped, (you said you replaced them).
              B. Not sure of the age but if there is a box on the side of the motor
              which houses points clean them with a fine piece of sand paper (wife's
              emery board works) then rub a penny thru them. Make sure when you
              crank the motor they are moving apart, set gap to manufacturer
              suggested speck. Their may be a screw to loosen so you will have to
              look.
              C. Remove a plug and attach the wire to the plug, ground the side of the
              plug to the motor and crank to see if you are getting spark. If not try
              re-grounding and move to the next plug if still no spark. Lots of checks
              here but check for bad wires. You will need someone with more
              knowledge or a service manual if still no spark. (make sure a fresh/
              charged battery is being used and the engine cranks well. If it cranks
              labored or slow check the battery and if no change there may be a
              timing issue (popping out the exhaust or breather is one sign but not
              always).
              Air- A. Remove air filter and check the path to the motor to ensure there are no restrictions/blockages.
              B. Clean/replace air filter.
              Hope this helps and try to get a service manual because it will help so much.
              HH 210MVP
              Spoolrunner 100
              Powercraft AC buzz box
              Lotas LTP5000D plasma
              Victor Oxy/Acet
              30 ton press
              A few brand name tools
              Lots of no name tools
              A wife to worry me
              and 4 dogs to supervise me
                If your not a mechanic you should probably either take it to one or have one help you out. You could create more problems that will cost you alot more in the long run
                  Im a weldor learning to be a bobcat 225g mechanic
                  Thank you all for the help.
                  I will find a service manual for this machine.
                  That's excellent advice.
                  It had been sitting about a month since last use. We have had a lot of rain here and it did get wet. I welded a project with it a few days ago but after using it an hour it stalled. It would start again, but wouldn't stay running more than a minute.
                  I don't even know how to drain the gas.
                  The spark plugs are new but I didn't set the gap.They looked like the old ones I removed so I put them in. I will set them properly with a gauge now.The plugs did get wet when I was cranking it, and I did smell gas.
                  It doesn't even start now and and it seems like it drains the battery while trying.
                  Spraying starting fluid into the carburetor helped before, but not now.
                  I bought it used so I don't know how old it is.
                  The serial # h987783979
                  The manual will help me keep up with the maintenance, which OBVIOUSLY is what it is lacking. After removing the covers I found some bird nests. It had been sitting around a farm awhile before I got it.
                  Thanks again. I love this website
                    did you check the oil? my bobcat 250 was shutting down after I changed the oil. it was hard to tell how high it was on the dipstick due to the new oil being so clear. ater I drained all the oil and then put some more in"the correct amount this time" that it ran perfect.
                      The oil had not been changed in a long time. It was dirty and black.
                      So I put the right quantity of 30 weight in,and of course new oil ,air and fuel filters.
                      I want to drain gas tank but do not know how to.
                      I'm going to check voltage of battery also.
                      Cleaning all the conectors is in my plan too.
                      I found an owners manual at miller.com. I need a service manual. I will keep searching. someone suggested ebay.
                        You need a service manual for the engine. On the side of the engine there should be a tag with the engine make/model & maybe some #s. For instance Kohler, Onan, Subaru etc. This would be the manual are searching for not a Miller specific manual.
                        MM250
                        Trailblazer 250g
                        22a feeder
                        Lincoln ac/dc 225
                        MM200 black face
                        Miller spectrum 875
                        RCCS-14
                          Symptoms are pretty consistent with water in fuel. I'd dump the carb bowl, and pump out the gas, or add some dry gas to the tank. Update your user cp with your location, maybe a local guy can help you out.
                            I haven't worked much on welders. Spent a lot of time turning wrenches on cars and bikes. Just a possibility-but if it starts, then quits, it might be a clogged vent line on your fuel tank. Sitting for a while the fuel will drain from the tank and fill the float bowl on the carb. The when you start it, supply can't meet the demand.
                            Without the venting the fuel tank will form a vacuum and not let the fuel flow. Just a guess! Good luck.
                              I had the carbureator cleaned properly by an expert and it runs like new
                              I have learned much from my experience here.the ethanol in fuel these days harms a carburator.its helpful to add stabil gas treatment to the gas to counteract the effects. Thanks
