Lets see pictures of your band saws
  • Lets see pictures of your band saws
    Here's my Ellis 1600 when it was almost new. I have enjoyed working with the saw, it's accuracy is amazing. I have gotten pretty good at figuring out how to clamp odd shaped work on it. I keep a pair of 12" vise grips by the saw for holding jobs the saw's vise can't hold properly and wood blocking to raise or put behind a work piece that has a bolt or something that keeps it from laying flat on the saw's table or up against the fence. I prop the head up with a 4X4 to keep pressure off the heads hydraulic lock and to keep the heads springs from stretching.
    I'm always saying my Ellis is the heart of the my shop. I couldn't work with out it.
    Nice, I have always wanted one but the old porta band gets me by.
    Don't have any room inside for one but what a difference it would make.
      I don't use my porta band much, I'm terrible at following a line with it, but those of you that do use yours seem to learn to make decent accurate cuts with them... I use mine mostly for making unusual cuts that can't fit on the Ellis or cutting off bolts.
      I was hoping to see other brands of band saws, guys interested in buying one could compare saws and ask owners questions all in one thread .
        Here is a video of my 4x6 Princess Auto saw with a home made oil cutting system.
        http://youtu.be/12M-yLlMvBQ
        She is no Ellis but I use it often for home use and it does great with a custom Lenox 6/8 tooth pitch blade.
          Pretty cool idea, does the oil ever cause the blade to slip on the wheels?
            Thanks got the idea off You Tube.
            Not so far.
            I use the saw weekly and the only issues I have had are the band coming off the drive wheel(this use to happen before the oiling system)
            The blade I use is a Lenox 6/8 tooth pitch;pretty aggressive and on the thinner stuff I need to control the feed pressure by hand or change to my standard 22 tpi blade.
            Trick is to get a light drip going to carry the chips away while improving cutting efficiency.
            There is a good video on YouTube detailing how to maximize your cut with these cheaper bandsaws.
              Not so far.
              Maybe a bushing or bearing is worn keeping the blade from running true. Got a link to the video? thanks for sharing ericher
                Nice Ellis saw. Erich, great idea , like that set up .
                  HF 4x6 cutting 4" soild round bar. I liked the saws with the formed arms not the cast ones...Bob
                    This is the how to adjust 4x6" saw and review link
                    It's a lengthy one but it pays off to watch and give this guys suggestions a try!
                    http://youtu.be/oImXgU3ATEk
                      I have a Rollin vertical band saw. I love it!! very simple and also very versatile, if you are thinking of buying a band saw I would look at these for sure. I will see if I can get some pics of it
                        I have a 1987 Enco 7X12 Horizontal/Vertical Bandsaw. It was built in Taiwan. It originally had a large coolant tank in the bottom of the chassis but it made a mess so I modified the saw. I changed it to a dry sump and used the original pump to raise the coolant up to the blade from a two gallon tank. I added a catch tray and raised the unit up on risers for easy cleaning. The coolant drains back down to the tank through a filter. I use Mobil soluble oil and the blades last a long time.
                        I welded the tank myself using 1/8" steel plate. The unit works quite well and will do a very straight, even cut.
                        The unit.
                        The coolant tank.
                        Miller Syncrowave 200
                        Milermatic 252
                        Lincoln AC/DC "Tombstone"
                          Thanks surfside. I have an Ellis belt grinder too, same quality, it never stalls and it's very easy to change belts. I wish I could afford an Ellis Drill press, they are built like tanks too.
                            That's impressive Bob. If your saw can cut that size of a round accurately it's good enough for most cutting jobs.
                              Pics would be nice cabininthewoods.
