help in choosing an arc welder
  • bigtow30t
    started a topic help in choosing an arc welder
    We I have not arc welded in over 20 years. I am looking to buy a dc welder (heard they are nicer to use).
    Now as far as amps I don't know what I'll need. I will need to weld 3/8" kind of often and 1/2" every now and then. Any input would be great
  • USMCPOP
    If you have the input power to run it, buy that Dialarc 250. It's been posted for a month so maybe the price is negotiable.
  • H80N
    Originally posted by bigtow30t View Post
    Thanks for all the input. Some of the thing I need it for is to fix semi trailers. For the mosr part I'll use my mm211, but some of the stuff is either to thick or can't get it as clean as you'd need for mig (rust pits).
    I guess I was more interested in what amperages I would need, more than what machine is better. I plan on getting a used one (for now), just got my mm211 6 months ago, so I have to save up again.
    Anyway I will need to weld 1/2" thick flange on a king pin slug through a hole 1/2" plate. So from what I'm seeing is id need 250 amps or so. Also is dc the way to go?
    250 amps is a good number... there should be somethig on the used market..
    here are the c/l search tempest listings within 100 miles of zip 48201
    http://www.searchtempest.com/results...min&maxAsk=max
  • bigtow30t
  • raferguson
    Used transformer welder
    I did a quick check on a local craigslist. The first thing that I looked at was 250 amps, Montgomery Ward, transformer welder, AC/DC, for $175. 250 amps is plenty of power, I would guess that 200 amps is plenty unless you plan to work with 1/2 inch thick plate. 200 amps will run essentially any 1/8 inch stick rod, and some larger rods. I would look for infinitely variable power rather than taps. I have had a 200 amp welder for years, and have never needed more power.
    As others have noted, you need to make sure that you have the AC power to support whatever you buy. As a starting point, think 220V and 50 amps, but the tag on the back should list the requirements for that particular welder. If you are limited to 30 amps I would consider an inverter welder.
    A used transformer welder will get you started, and you can always sell it for what you paid for it, if you decide to upgrade. My vote is to start simple and cheap, and you may find that it will meet all your needs. A 110V MIG welder is also cheap on the used market, and will be better than a stick welder for sheet metal.
    Richard
  • BD1
    This is real. He really didn't explain his situation fully except that he wants to weld 3/8 and 1/2 . He has a Miller 211 already so I just stated what I thought was the best machine for what he wanted and would not grow out of. He may have just won the lotto so he has bucks. He never said his budget was $ 100.00 either.
    So, if a guy hasn't driven a car in 20 years doesn't mean he won't go buy a Caddy or Lincoln either.
  • Precision
    ^lol.
  • USMCPOP
    BD1,
    A fellow who hasn't stick welded in 20 years and heard DC is "nice" isn't likely to need a $2,000. inverter welder. Get real.
  • BD1
    If your looking for a inverter, go with the Miller CST 280. These are used daily at work and it is a 220 volt machine only. Awesome for 6010 / 7018, that's all we burn. PLUS it is 100 % duty cycle at 150 Amps.
    http://www.millerwelds.com/products/stick/cst-280/
    http://www.millerwelds.com/om/o217655e_mil.pdf manual
  • USMCPOP
    There's an exceptionally clean Dialarc 250 on CL in Monroe, MI. It would be a good buy if you could get it for maybe $400. (if you have enough power available to run it).
    http://monroemi.craigslist.org/tls/3957228199.html
    Hobart Stickmate ac/dc $250 in Fenton:
    http://flint.craigslist.org/tls/4026210254.html
  • H80N
    Could you give us more details of your intended use??
    if you are planning 3/8 & 1/2 inch steel with stick?..... Would count on at least a 250 amp machine..
    Home Hobby use?? Limited budget?? .... if so I would hunt for a used "Thunderbolt AC/DC" or equiv in the local pennysaver or Craigslist...
    should be able to find something in the $100-250 range pretty easily...
    Dialarcs show up pretty regularly in that price range Too... Even Better.!!
  • Manisoba
    Depends on how much you want to spend. If it was me looking for a new stick I'd probably go with a maxstar 150 or 200.
