grinding out a curve on square or round bar.
  • grinding out a curve on square or round bar.
    Is there any machine that would make grinding out a curve in order to hold round bar any easier/quicker?
    Try a hole saw in a drill press easy and cheap
      Hole saw in a good drill press
      Edit- if you are only doing set ups like in yer pic then a hole saw in a DP but for any angles you'll need a Tube Notcher
      http://www.jd2.com/t-notchercomparison.aspx
      You can Google or you tube notchers to see how they work.
      Edit #2
      You can also use your Chop saw on Tubing
      http://www.pirate4x4.com/forum/shop-...-pictures.html
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        Guys thanks very much, I just wouldn't have thought of the hole saw.
          Those pipe Notchers look great.
            I have the jd2 its pretty good. Had to mess with the alignment of the clamp when I first got it. It was little off center, but now it's good. Don't buy a cheap one or you will be fighting it
              No more cheap stuff for me, I've found that out the hardway better to save and do it right. Thanks again for the info. I
                Make a template from sheet metal to trace it then use a torch or plasma cutter. Or make a thicker template that you can just run the torch around or a plasma cutter. Have the radius figured out for either the torch or pc to have it cut exactly where you want the hole. Should only be a minute on each side and they should be perfect with no grinding if done right...Bob
                  I don't have it yet, but this is on my list. Baileigh tube notcher TN 250
                  http://metal.baileighindustrial.com/tube-notcher-tn-250
                    I've always just cut these out with a torch, dress up a bit with a grinder. Unless you are doing hundreds and thousands of these, I cannot understand spending stupid amounts of money to replicate the same cut, over and over again.
                      V-blocks
                      I'm a little late with a reply. Work too much-visit too little! From your pictures, it looks like you are trying to hold round stock in position. When I was working as a machinist-we always secured round stock for milling with v-blocks in our milling vise. It automatically centers, and in your case, changing the tops of your stands to a "v" with plate-it will handle different sizes of round stock without changing anything. Just my opinion. Always looking for a better way to do it!
                        Looks like you only have a few.....just take a small drop of the round stock, turn it sideways and lay against the side of tube. Measure the depth you want the notch with a combo square for consistency. Mark with soapstone and burn, plasma or drill. If you lay the hole out before cutting the metal you can center punch and use a hole saw without a drill press. Then just cut it afterwards. Dave
