So I have a MultiMatic 200 and I'm wondering what generator I get to run my welder at MAXIMUM performance? Got any suggestions? Thanks guys!
What generator would be good for a mm200?
Considering the input power needed to run your machine, I would say that a 3000 continuous watt generator would be plenty. As for the brand, that would depend on your budget.JIM
Owner Operator of JNT Mobile Welding & Repair LLC
Millermatic 350P Aluma Pro
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
Hypertherm Powermax 45 and 85
Ingersoll Rand Engine Driven Compressor
Dake 75 ton H-Frame Press
JD Squared Model 32 Bender
Miller Digital Elite
Originally posted by Sberry View PostA MM200 is pretty hefty, its a 50A service machine. I would think 8 K or better.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Hahahah! Sorry guys, I was just trying to abreviate my title... But I have a coleman that's rated at 3600 continuos, It has an 8 hp brigs and straton on it, its older.... when I start to weld itbogs down and dies on minimum settings. And as for quality either 1st or 2nd teir brand name generators
Originally posted by jpence38 View PostConsidering the input power needed to run your machine, I would say that a 3000 continuous watt generator would be plenty. As for the brand, that would depend on your budget.
3000/240v= 12.5 amps
The Multmatic draws 18amps at rated 150 welding amps Mig and 20 amps Stick
20amps x 240v = 4800 watts continuous so yer looking for a genset that is around 5500wattsEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by Broccoli1 View PostThat's still way too small for the multimatic
As for the brand, I have always went with the Generac and have never been disappointed.
In my opinion, Generac and Honda are at the top of the list.Last edited by jpence38; 08-10-2013, 04:58 AM.JIM
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
Originally posted by Hardrock40 View PostI'm surprised somebody hasn't already suggested an engine drive weld machine.
A bit more weight and price but you can open many more doors by going that route.
Originally posted by Manisoba:310567Originally posted by Hardrock40 View PostI'm surprised somebody hasn't already suggested an engine drive weld machine.
Originally posted by weldonwelding View PostMy bobcat says 11,000watt on the cover... but its something like 9500watt continuous
For some reason I didn't realize that, Mine is the same and I was thinking they were stating 11,000 continuous but I guess it's not. Its Accu-Rated,,, LOL well crap.
From Miller:
Accu-Rated™– Not Inflated Generator Power
Miller’s Accu-Rated™ 11,000 watts (12,000 with EFI) of usable peak power is delivered for a minimum of 30 seconds. Accu-Rated means peak power is usable for maximum generator loads such as plasma cutting, Millermatic® MIG welders and motor starting. Accu-Rated peak power beats the competition’s very shortduration peak or surge power. Use your peak power, it’s more than a number.
Tractor Supply had a Generac 7500(continuous 9350 peak) for $800 last month. That's way less than a good used bobcat with a 2 yr warranty. Guess the big question is are you gonna run it for 40+ hrs a week or bout 4. If you gonna work the thing then you need a bobcat.
