bobcat 225 dying issue
  • bobcat 225 dying issue
    I've got a 2010 bobcat 225 with the Robin/Subaru motor that I acquired with 70 hours on it a little while back. I've had it in my truck about a month. When I crank it the first time in the morning it runs good about 45 seconds then bogs down and dies blowing dark smoke. Its always about 15 -25 seconds after it idles down from start up. Then when I restart it acts flooded then goes ahead and starts and is fine all day. Sometimes it does it after lunch if I take a very long one. I'd appreciate any advice or help. It ain't keeping me from work but it is something I worry about. Thanks a lot!
    A serial# would be handy, is it a front or rear engine unit?
      Rear motored if rear is where the motor is opposite the control panel. I'll get the serial # to ya soon as I can, I'm outa pocket. Thanks a bunch!
        The serial # is LK21519H
          It's just a guess at this point without more information, but it sounds to me like the carburetor float needle valve is not closing completely and the fuel pump is over filling the float bowl, which then causes the motor to run rich and stall. This would produce the "flooded" condition on restart too. I would replace both the float needle valve and the float, since older floats frequently either leak or absorb fuel and no longer float at the correct level.
          Charley
          ______________________________
          Miller MM252
          Miller Bobcat 225NT
          Miller DialArc HF & DIY Cooler
          2 Miller Digital Elite and 3 Fixed Shade Helmets
          2 O/A torch sets
          DeWalt 18 volt 1/2" Driver/Drill
          DeWalt 18 volt 6 1/2" Metal Saw
          DeWalt Porta Band & SWAG Offroad V3 Table
          Milwaukee 8" Dry Cut Saw
          Milwaukee 14" Dry Cut Chop Saw / Delta Stand
          Milwaukee 9" Grinder
          2 Milwaukee 4 1/2" Grinders
          Milwaukee Hole Hawg 1/2" Drill
          Wallace 5 Ton Gantry
          Too many hand tools
            Charley
            Yes that was my first thought but it does it at the same time every cold start methodically. If it were a bad needle and seet or float wouldn't it do it all the time?
              Sounds like the choke is staying on too long.
              My own shop since 1981
              Cya Frank
