which electrode for welding titanium?
  • which electrode for welding titanium?
    bout to begin first titanium welds, ordered filler rod at 63.oo a lb. wats best electrode fir job ?
    From previous post. I've read your unsure of your base metal why would you go out and spent money yet. Have you done any test.. titanium isn't magnetic.
    If grind on it puts out bright white sparks.
    Unlike mild steel which are yellowish.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    (Retapped to fit regular mig tips)
    Work better & less parts to stock.
    Miller 130xp
    T/A Dragster 85 (portability 11 pounds)
    Oxygen/Acetylene torch set 50'
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
      i appreciate ur input, its out of necessity. nor for fun
        Well then, Fur those welds I use 1/4" since it for ( Necessity )
          Best Practices Titanium TIG
          Since you are diving into the pool headlong without any previous Titanium TIG experience... maybe you will find these articles helpful in giving you some of the basics...
          Titanium 101: Best TIG (GTA) Welding Practices
          http://www.millerwelds.com/resources...anium-welding/
          and
          http://www.millerwelds.com/resources...ium-tube-pipe/
          Maybe shine a little light on the subject..
            I use 2% lanthanated, but any electrode suitable for DCEN is fine.
            Filled by Zanconato Custom Cycles, on Flickr
            Mike Zanconato
            @mzank on Instagram
            Dynasty 280DX
            Meco Midget
              thanx to all
                thats a nice consistent bead width.... how does titanium filler flow ? like steel or like aluminum ?
                Syncrowave® 200
                Lincoln AC/DC 225/125
                Lincoln Weld Pak 100 wire feed
                  Flows very nice. And the puddle is bright and shiny. It's a lot like welding stainless. The one thing I find challenging if I'm not 100% focused is that the tip of the filler rod can get stuck on the base metal on the leading edge of the puddle or if it touches anywhere else on the base metal. I try to be very deliberate with my dabs and I try to feed closer to the center of the puddle. The tip of the filler seems to stay molten and will freeze off on whatever it touches that isn't molten.
                  I also pay very close attention to torch angle and shielding as I am coming up to an outside corner or moving around a tube. The weldment shape can block the shielding ahead of the puddle if you don't anticipate it. It's pretty agonizing when things all of a sudden go blue and purple around a corner because of torch angle.
                  Mike Zanconato
                  @mzank on Instagram
                  Dynasty 280DX
                  Meco Midget
                    thanks so much for your input
                    Syncrowave® 200
                      Lets us know how it works out. Pics are always nice aswell
                        appreciated all
