Hello, I have a need for using my new Miller 175 Mig welder outside, to weld patch panels on a old truck restoration and I would like to be as far as I can ( 120'if possible ) from my receptacle in my garage.I have a 30 amp breaker, approx. 9 feet of 10 guage wire that comes off my circuit breaker to the receptacle in my garage.The Millermatic 175 Mig welder says it requies 230 volts @ 19.5 Amps.I have thought about using either a 10-3 or 8-3 guage cord for making an extension cord up.Will I have any problems with this set up, or is there a maximum distance that I could go with an extension cord ? I don't want to risk damage to the new welder, but to work on the old truck, I will need as much distance as I can get from an extension cord.The manual said a max. conductor length of 66 feet, but it also said to use a Min. conductor size of 14 guage wire.Was the max feet of cord recomended, based on a conductor size of 14 guage ? thanks for any help you can give me in this matter.
Millermatic 175 extension cord
I would use 8-3 just in case you get a heavier welder later on. I paid $35 for a 25' piece of SOW w/o plug or receptacle. 10-3 is a bit cheaper. Got mine from Welding Depot.
http://www.weldingdepot.com/?source=overture
