Need to make steel rings
  • Need to make steel rings
    Hi would this machine be able to bend a 25 mm/ 1 inch bar into a 360? If anyone has and recommendations I'd appreciate. I don't have any heat (propane). I'm trying to avoid renting.
    With that bender you may have to make the rings in halves and weld them together...Good luck
      1" steel bar, no heat, and that radius? I think you are in trouble.
      CG
      Miller Diversion 165
      1945 Craftsman Atlas Lathe
      Smithy Lathe/Mill
        No it won't. That is a tubing bender & you are asking about bar. Big difference.
        MM250
        Trailblazer 250g
        22a feeder
        Lincoln ac/dc 225
        MM200 black face
        Lown 1/8x 36" power roller
        Arco roto-phase model M
        Vectrax 7x12 band saw
        Miller spectrum 875
        30a spoolgun w/wc-24
        RCCS-14
          Could it be done with heat and that bender? I've been on to a gas supplier and now you can buy the propane canister/cylinder. So I will have heat.
            Bayweld I never even though of welding the two halls together, genius!!
              No
              Round Tube Capacity 7/8"
              Wall Thickness .047"
              Square Tube Capacity 1"
              Ed Conley
              MM252
              MM211
              Passport Plus w/Spool Gun
              TA185
              Miller 125c Plasma 120v
              O/A set
              SO 2020 Bender
              You can call me Bacchus
                Burn em from 1" steel plate and do a round over to suit...Bob
                  How many do you need to make?
                  this might work for you
                  http://www.westechrigging.com/riggin...are-rings.html
                  Ed Conley
                  MM252
                  MM211
                  TA185
                  O/A set
                  SO 2020 Bender
                    You can heat bar stock in a forge and bend them around a piece of tube with no problems. Forge is easy to make.
                      I would either sub it or burn them from plate
                        Question to the op.
                        How many do you need to make/buy? What exactly is the use?
                        MM250
                        Trailblazer 250g
                        22a feeder
                        Lincoln ac/dc 225
                        MM200 black face
                        Miller spectrum 875
                        RCCS-14
                          You can buy those.... http://www.liftingsafety.co.uk/produ...ings-2424.html
                            @turbo they're a bit pricy at 21£
                              @mmw initially 10 for Highland games, but if I get the bending right I've railing to make up so plenty of bending to be doing 180's though not 360's bends.
