I am trying to get a good weld on new 1/4 inch angle iron. I have set the machine on the recommended settings for 1/4 inch material but it doesn't want to start in the flat and is way cold. Can someone give me all the settings you would use on this application.
350 P mig welder
Originally posted by BearM View PostThe 350p is the easiest machine to work with, IMO. Flip the flap on the front and read. Set all the settings and you can pull up a chair and kick back.
Make sure your drive rolls are tensioned properly and are not slipping. Make sure the tension on the wire spool is free and not binding. Contact tip clean and free too. If all of that is fine, turn up your wire speed.sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
A system reset function is available that
completely resets unit back to all the
original factory settings.
To access this menu, turn on welding power
source, then press the SETUP (1) button
when the SETUP light illuminates under the
Left display.
SRST will appear on the left display and OFF
will appear on the right display.
To prepare the unit for system reset, rotate
right knob until ON appears on the right
display.
To apply the system reset function, press
SETUP (1) button, and wait until unit
completely reboots before performing any
other operations.
With my unit, I had to hold the setup button while turning on the power. Good Luck!
inductance
try turning the inductance up. i like to run it about 80 to 85. lays a hotter flatter bead and seems to cut down on spatter. also for a hotter smother start i set the run in at 40%. also make shure you have process, wire, and all other presets set to your job.Miller Syncrowave 200
Miller Spectrum 875 Plasma Cutter
Miller Milermatic 135
Ridgid Drill Press
Ridgid Chop Saw
36" Metal Break
Harris Toarches
English Wheel
Ingersoll Rand, 18.1 cfm Compressor
30 gal. Sand Blaster
Planishing Hammer
150lb Anvil
10" Swing Logan Lathe
350 P mig welder
Ck your ground. I replace the junk ground clamp with a good brass one. Grind a spot clean where apply ground. Also ck gas & make sure correct flow at gun. Put new bottle on last month & same type problem. Had to remove reg. clean, blow out opening etc. then up & running normal.
Originally posted by hunter59:308876Originally posted by BearM View PostThe 350p is the easiest machine to work with, IMO. Flip the flap on the front and read. Set all the settings and you can pull up a chair and kick back.
What are your setting at the moment.
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
