What are all the power sources that will run the suitcase welder? Thanks, Tom
Suitcase Extreme 12 vs
Check out the manual.
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
I weld with mine hooked up to 225 bobcat,302 TB and 300 classic.Not all at the same of course. Works fine on heavy equipment repairs. I guess it would work on Miller thunderbolt as long as it puts out enough voltage for the drive motors to run and burn the wire.
If you do a search, you'll see hat they operate best on machines with CV output.
CC output machines will work with really heavy stuff and flux core apparently.
The feeder can't adjust the feed rate fast enough on CC to mimic true CV short circuit mig.
